Eton FRX5-BT Case Disassembly
  1. Eton FRX5-BT Case Disassembly, Remove plastic cap: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Press on the left most side on the small plastic cap on the back of the radio (it is loosely glued in place).
    • When the plastic cap comes loose, remove it completely to access the lock mechanism below.
  2. Eton FRX5-BT Case Disassembly, Remove the solar panel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the lock mechanism all the way to the left. Now the solar panel is no longer locked in place.
    • Remove the solar panel, by lifting it on the top part. You can use a suction cup or carefully tilt the device when it's in an upright position.
    • Be mindful on the wire connecting the solar panel to the rest of the device.
  3. Eton FRX5-BT Case Disassembly, Remove screws: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the six 2.5mm Hex screws.
  4. Eton FRX5-BT Case Disassembly, Open the case: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the two halves of the device case apart.
    • There are no wires connecting the two parts of the case, but the solar panel wire goes through a hole in the back case and connects it to the rest of the device.
Martin
crwdns2935283:006/06/24crwdne2935283:0
154 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 54
crwdns2942667:0crwdne2942667:0 418
