crwdns2860944:0crwdne2860944:0
crwdns2860947:0crwdne2860947:0
crwdns2890040:0crwdne2890040:0
crwdns2882210:0crwdne2882210:0 crwdns2882211:0crwdne2882211:0
Pull the plastic tab on the battery compartment cover panel to loosen it, then pull the panel off.
Disconnect the battery pack wires from the device and remove the battery pack.
On the bottom of the device case's face are two T10 screws. Use a T10 Torx screwdriver to remove the two screws.
While using the T10 screwdriver, remove the two T10 screws on the back of the device's case.
Remove the two Phillips #00 screws located in the center of the back of the device.
On the bottom of the device's case there are two rubber feet. Pry the rubber feet off of the case.
Pull the two halves of the device's case apart.
The solar panel is connected to the motherboard through a simple socket, just pull up to unplug.
The solar panel is not glued or soldered in place, you can simply lift the panel straight up from it’s seating to remove.
