Eton FRX3 Case Assembly Replacement
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Eton FRX3 Case Assembly Replacement, Rechargeable Battery Pack: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the plastic tab on the battery compartment cover panel to loosen it, then pull the panel off.
  2. Eton FRX3 Case Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the battery pack wires from the device and remove the battery pack.
  3. Eton FRX3 Case Assembly Replacement, Case Assembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the T10 hexagonal tip from the iFixit Bit Driver Kit or comparable tool to remove the two 22 mm hexagonal screws on the front face of the device.
  4. Eton FRX3 Case Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 22 mm hexagonal screws on the upper rear of the device.
  5. Eton FRX3 Case Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a long, slender screwdriver to reach and remove the two 10 mm Phillips #00 screws recessed deep in the body of the device.
    • If you're using the 54-bit toolkit, the female hexagonal bit can be used to extend the reach of the Phillips #00 bit.
  6. Eton FRX3 Case Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • On the bottom of the device are two rubber feet. Using the blue plastic opening tool, pry them up and pull straight off.
    • It’s best to place these on their non-sticky side while you work, as you’ll want them to keep as much tackiness as possible for reassembly.
  7. Eton FRX3 Case Assembly Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull apart the two halves of the device at the seam.
    • Three components from the back half will prevent you from fully opening the device, just unplug these connections as shown in the image.
Kenneth Sills
crwdns2935283:002/10/16crwdne2935283:0
762 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-6, Nance Spring 2016 crwdns2935289:0USF Tampa, Team 1-6, Nance Spring 2016crwdne2935289:0
USFT-NANCE-S16S1G6
crwdns2935297:013crwdne2935297:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 70
