Eton FRX3 AM Radio Internal Antenna Replacement
  1. Eton FRX3 AM Radio Internal Antenna Replacement, Rechargeable Battery Pack: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the plastic tab on the battery compartment cover panel to loosen it, then pull the panel off.
  2. Eton FRX3 AM Radio Internal Antenna Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the battery pack wires from the device and remove the battery pack.
  3. Eton FRX3 AM Radio Internal Antenna Replacement, Case Assembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • On the bottom of the device case's face are two T10 screws. Use a T10 Torx screwdriver to remove the two screws.
  4. Eton FRX3 AM Radio Internal Antenna Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • While using the T10 screwdriver, remove the two T10 screws on the back of the device's case.
  5. Eton FRX3 AM Radio Internal Antenna Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two Phillips #00 screws located in the center of the back of the device.
    • You will need to use a thin shafted screwdriver or a female hexagonal bit that is found in the iFixit 54 bit toolkit to extend the reach of the Phillips #00 bit.
  6. Eton FRX3 AM Radio Internal Antenna Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • On the bottom of the device's case there are two rubber feet. Pry the rubber feet off of the case.
    • Try to keep the adhesive on the rubber feet as clean as possible to insure that they can be reattached during reassembly.
  7. Eton FRX3 AM Radio Internal Antenna Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the two halves of the device's case apart.
    • Take care when pulling the two halves apart. There are three cables that connect components of the device to the motherboard. Disconnect these cables in order to separate the two halves of the device's case.
  8. Eton FRX3 AM Radio Internal Antenna Replacement, Tuning Dial: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the socket connection from the motherboard as shown in the image.
  9. Eton FRX3 AM Radio Internal Antenna Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 1 cm Phillips #0 screws that secure the tuning dial panel to the motherboard.
  10. Eton FRX3 AM Radio Internal Antenna Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the dial upwards to remove it.
  11. Eton FRX3 AM Radio Internal Antenna Replacement, Motherboard: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the six Phillips #0, 1 cm screws that secure the motherboard to the case.
  12. Eton FRX3 AM Radio Internal Antenna Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug all the component socket connections from the motherboard.
  13. Eton FRX3 AM Radio Internal Antenna Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Desolder the two wires that connect the speaker to the motherboard.
  14. Eton FRX3 AM Radio Internal Antenna Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the motherboard upwards to remove it from the device.
  15. Eton FRX3 AM Radio Internal Antenna Replacement, AM Radio Antenna: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • On the back of the motherboard, remove the two Philips #0 screws.
  16. Eton FRX3 AM Radio Internal Antenna Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the circuit board back over. Proceed to desolder the two thin wires from the AM antenna, that are soldered to the circuit board.
    • Gently pull the AM antenna straight up, out of its housing, to remove it from the circuit board.
To reassemble your device, follow these instructions in the reverse order.
Kenneth Sills
crwdns2935283:002/10/16crwdne2935283:0
762 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-6, Nance Spring 2016 crwdns2935289:0USF Tampa, Team 1-6, Nance Spring 2016crwdne2935289:0
USFT-NANCE-S16S1G6
crwdns2935297:013crwdne2935297:0
crwdns2942667:0crwdne2942667:0 1,185
