crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Eton Elite Minicrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Eton Elite Mini Teardown, Prep for Teardown: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Eton Elite Mini Teardown, Prep for Teardown: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Eton Elite Mini Teardown, Prep for Teardown: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before you begin. Make sure that the device is turned off and the batteries have been removed.
    • To remove the 2 AAA batteries. Press your thumb on the grooves of the battery cover (on the lower back of the radio) and move your thumb downward.
    • You'll see a black battery ribbon once the battery cover has been removed. Gently tug on the battery ribbon to remove the batteries from the compartment.
  2. Eton Elite Mini Teardown: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Eton Elite Mini Teardown: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Be careful when pulling on the battery ribbon. Even tugging on it gently can cause the batteries to fly out of the battery compartment. To avoid losing the batteries or injuring yourself or someone else, place your hand over the battery compartment to stop the batteries from flying out.
  3. Eton Elite Mini Teardown, Screw Removal: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Eton Elite Mini Teardown, Screw Removal: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Eton Elite Mini Teardown, Screw Removal: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • For these steps you will need your #000 Philips Head screwdriver bit.
    • Place the radio face-down so the back panel is visible. Then unscrew the four screws located on the top and middle of the back panel.
    • The two top screws are smaller then the two middle screws. If you think you might want to put this back together again it's important to remember where to put each size screw so as to not mess up any internal components.
    • There are two screws inside the battery compartment that also need to be unscrewed. The #000PH will work for this step too. These screws are just as long as the middle screws from the back plate.
  4. Eton Elite Mini Teardown, Prying Apart the Backplate: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take your spudger and put it between the back plate and the actual radio compartment. Slowly guide it along the edges to remove.
    • Be careful when guiding the spudger through. There are plastic clips that connect these two pieces together. If you plan on reassembly, be careful not to break these.
    • If you don't have a spudger, you can use picks to do the same thing.
  5. Eton Elite Mini Teardown, Done: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once you've successfully pried the back plate off, you will have access to all of the internal components of the radio.
This isn't really a disassembly video. It's only partially disassembled. I can't imagine why you'd want to take it only this far. You have no access to either of the pc boards to troubleshoot or repair the radio.
Larry Wolken - crwdns2934203:0crwdne2934203:0
@larrywolke13251 , it's not meant to be a video. Just a step-by-step guide of tearing it down without totally ruining it. But, it's a fair point. It's not a complete disassembly. If you end up taking it apart completely, feel free to add to the guide or create a new one. I updated this guide to be more accurate.
Kris Rodriguez -
crwdns2936753:030crwdne2936753:0 43
crwdns2942667:0crwdne2942667:0 895
