Ethernet Port Replacement
  1. Ethernet Port Replacement, Linksys EA6900 Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ethernet Port Replacement, Linksys EA6900 Disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ethernet Port Replacement, Linksys EA6900 Disassembly: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the antennas by unscrewing them from the base.
    • Flip over the device and locate the four rubber feet on the bottom.
    • Remove the rubber feet with tweezers
  2. Ethernet Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 0.4cm head screws from each slot with the #1 Phillips head Screwdriver.
  3. Ethernet Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a blue plastic opening tool to remove the top cover.
    • Move the blue plastic opening tool gently underneath the top cover from side to side.
  4. Ethernet Port Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ethernet Port Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ethernet Port Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently lift the motherboard and remove it from the case
    • Put the motherboard over a (preferably white) surface.
  5. Ethernet Port Replacement, Ethernet Ports: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ethernet Port Replacement, Ethernet Ports: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ethernet Port Replacement, Ethernet Ports: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the Ethernet ports
    • Flip the motherboard and locate the 40 solder points corresponding to the Ethernet ports
    • Melt the 40 solder points using a soldering gun.
    • Wait between five and seven minutes for the ports to cool down.
  6. Ethernet Port Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Hold the motherboard down and use the spudger to remove the Ethernet Ports.
Denis
crwdns2935283:009/15/16crwdne2935283:0
611 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 11-1, Blackwell Fall 2016 crwdns2935289:0USF Tampa, Team 11-1, Blackwell Fall 2016crwdne2935289:0
USFT-BLACKWELL-F16S11G1
Can you make a guide to replace the antenna base connector, mine get broken at the base, I wonder if it is possible to make the cable connection directly to the antenna, does that could work?
Enrique Jendrix - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 51
crwdns2942667:0crwdne2942667:0 8,099
