Etekcity Lasergrip 1080 Trigger Replacement
  1. Etekcity Lasergrip 1080 Trigger Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the battery cover away from the handle by gripping near the thumb groove.
  2. Etekcity Lasergrip 1080 Trigger Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull the battery out of the handle.
    • Excessive force could damage wires.
  3. Etekcity Lasergrip 1080 Trigger Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Etekcity Lasergrip 1080 Trigger Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the battery by pulling the connector away from it.
    • Positive first
    • Negative second
    • When replacing the battery, this order is reversed.
  4. Etekcity Lasergrip 1080 Trigger Replacement, Buttons: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Etekcity Lasergrip 1080 Trigger Replacement, Buttons: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery cover from the device by pulling it straight out.
  5. Etekcity Lasergrip 1080 Trigger Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Etekcity Lasergrip 1080 Trigger Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the plastic opening tool remove the front and rear yellow covers.
    • When removing the back cover, be careful not to lose the buttons as they are not connected.
  6. Etekcity Lasergrip 1080 Trigger Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 3.1 mm Phillips #0 screws.
  7. Etekcity Lasergrip 1080 Trigger Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Etekcity Lasergrip 1080 Trigger Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the two halves apart.
    • Be careful not to lose any components on the inside.
  8. Etekcity Lasergrip 1080 Trigger Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Realign the buttons with the button terminals.
    • Red terminal to red button.
    • Orange terminal to orange button.
    • Yellow terminal to yellow button.
  9. Etekcity Lasergrip 1080 Trigger Replacement, Etekcity Lasergrip 1080 Trigger Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Etekcity Lasergrip 1080 Trigger Replacement, Etekcity Lasergrip 1080 Trigger Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully pull the trigger out.
    • The trigger is spring loaded, so be careful that you do not lose the spring as you pull the trigger out.
    • To put the trigger back in, align the peg with the hole in the handle and align the shaft with the button terminal.
Patrick Crawford
crwdns2935283:008/26/15crwdne2935283:0
783 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 5-1, Blackwell Fall 2015 crwdns2935289:0USF Tampa, Team 5-1, Blackwell Fall 2015crwdne2935289:0
USFT-BLACKWELL-F15S5G1
crwdns2942667:0crwdne2942667:0 762
