Etekcity Lasergrip 1080 Motherboard Replacement
  1. Etekcity Lasergrip 1080 Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the battery cover away from the handle by gripping near the thumb groove.
  2. Etekcity Lasergrip 1080 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull the battery out of the handle.
    • Excessive force could damage wires.
  3. Etekcity Lasergrip 1080 Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Etekcity Lasergrip 1080 Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the battery by pulling the connector away from it.
    • Positive first
    • Negative second
    • When replacing the battery, this order is reversed.
  4. Etekcity Lasergrip 1080 Motherboard Replacement, Buttons: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Etekcity Lasergrip 1080 Motherboard Replacement, Buttons: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery cover from the device by pulling it straight out.
  5. Etekcity Lasergrip 1080 Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Etekcity Lasergrip 1080 Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the plastic opening tool remove the front and rear yellow covers.
    • When removing the back cover, be careful not to lose the buttons as they are not connected.
  6. Etekcity Lasergrip 1080 Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 3.1 mm Phillips #0 screws.
  7. Etekcity Lasergrip 1080 Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Etekcity Lasergrip 1080 Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the two halves apart.
    • Be careful not to lose any components on the inside.
  8. Etekcity Lasergrip 1080 Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Realign the buttons with the button terminals.
    • Red terminal to red button.
    • Orange terminal to orange button.
    • Yellow terminal to yellow button.
  9. Etekcity Lasergrip 1080 Motherboard Replacement, Etekcity Lasergrip 1080 Trigger Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Etekcity Lasergrip 1080 Motherboard Replacement, Etekcity Lasergrip 1080 Trigger Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully pull the trigger out.
    • The trigger is spring loaded, so be careful that you do not lose the spring as you pull the trigger out.
    • To put the trigger back in, align the peg with the hole in the handle and align the shaft with the button terminal.
  10. Etekcity Lasergrip 1080 Motherboard Replacement, Laser: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the motherboard out of its slot in the device.
  11. Etekcity Lasergrip 1080 Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a soldering iron to melt the solder that holds the wires for the laser to the motherboard.
    • Soldering irons are hot and should only be handled by those who know what they are doing and are wearing proper safety equipment. There is a link to a soldering guide in the Troubleshooting section of the device page.
  12. Etekcity Lasergrip 1080 Motherboard Replacement, Sensor: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  13. Etekcity Lasergrip 1080 Motherboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a soldering iron, melt the solder that holds the wires for the sensor to the motherboard.
  14. Etekcity Lasergrip 1080 Motherboard Replacement, Battery Connector: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  15. Etekcity Lasergrip 1080 Motherboard Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a soldering iron and melt the solder where the battery connector's wires are attached to the motherboard.
  16. Etekcity Lasergrip 1080 Motherboard Replacement, Screen: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully pull the motherboard out of its slot in the body of the device.
  17. Etekcity Lasergrip 1080 Motherboard Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Etekcity Lasergrip 1080 Motherboard Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the two 3.4 mm screws on the motherboard.
  18. Etekcity Lasergrip 1080 Motherboard Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take off the cover and separate the parts.
    • All of these parts are fragile and mishandling them may cause damage.
Patrick Crawford
crwdns2935283:008/26/15crwdne2935283:0
783 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 5-1, Blackwell Fall 2015 crwdns2935289:0USF Tampa, Team 5-1, Blackwell Fall 2015crwdne2935289:0
USFT-BLACKWELL-F15S5G1
crwdns2942667:0crwdne2942667:0 662
