This guide will teach you how to replace buttons that are not functioning properly. This will use a screwdriver and a plastic opening tool. There are no hazards involved.
Pull the battery cover away from the handle by gripping near the thumb groove.
Gently pull the battery out of the handle.
Disconnect the battery by pulling the connector away from it.
Positive first
Negative second
Remove the battery cover from the device by pulling it straight out.
Using the plastic opening tool remove the front and rear yellow covers.
Remove the two 3.1 mm Phillips #0 screws.
Realign the buttons with the button terminals.
Red terminal to red button.
Orange terminal to orange button.
Yellow terminal to yellow button.
