crwdns2862591:0crwdne2862591:0
crwdns2862592:0crwdne2862592:0
crwdns2959928:0crwdne2959928:0 ↓Smartphone batteries will naturally degrade as you use your phone over a matter of years. This will cause the battery life to be shorter than it was when you first started using the phone. Use this guide to replace your Essential Phone's battery or to remove it to access other components of the phone.
Note: A verified replacement battery for the Essential Phone is currently hard to find, so keep that in mind when performing a battery replacement.
If possible, drain the battery before disassembly. When the battery is charged, there's increased risk of a dangerous thermal event if the battery is overheated or damaged during repairs.
Heat the perimeter of the display to soften the adhesive securing it.
If available, use a hot plate or heat pad. Place the Essential Phone face-down and heat it to 85° C for at least 15 minutes.
Otherwise, use a heat gun to evenly heat the entire perimeter of the display until it's too hot to touch. Try to maintain a high temperature for 15-20 minutes—but beware that without exact control over the temperature, you can easily destroy the display.
For reference, the back of the display panel is shown at left. Note the contours of the display panel. Tools can only safely be inserted into the camera notch at the top, and along the very thin (just over 1 mm) black bezel surrounding the display.
crwdns2935267:0crwdne2935267:0Heavy-Duty Suction Cups (Pair)$16.95
While the phone is still hot, apply a heavy-duty suction cup to the top half of the display.
After positioning the suction cup, gently press down, and then close the handle to securely fasten the suction cup to the display surface.
Pull on the suction cup handle to open a slight gap between the top edge of the display and the Essential Phone's titanium enclosure.
Insert a thin blade or pry tool into the camera notch at the top of the display.
Use your suction cup and blade or pry tool to widen the gap at the top of the display until you can insert a second tool under the glass, closer to the corner.
crwdns2935267:0crwdne2935267:0Halberd Spudger$2.99
Insert a halberd spudger no more than 1 mm under the display, and cut the adhesive all along the top edge.
Continue carefully separating the adhesive at the top corners and down both sides of the display.
Pull carefully on the suction cup to swing the top edge of the display away from the chassis.
Carefully open the clamp on the suction cup to release the suction, and remove the suction cup.
Swing the display open to about 90° and prop it up against something sturdy so it doesn't move while you work.
If needed, gently add a rubber band to help secure the display.
Use a Phillips #00 driver to remove the two 1.5 mm screws securing the display cable.
Carefully slide a pick underneath the display cable to separate the adhesive securing it to the metal shield beneath.
Use the point of a spudger to pry the display cable pop connector straight up from its socket.
Use your halberd spudger to carefully separate any remaining adhesive along the bottom edge of the phone.
crwdns2935267:0crwdne2935267:0Tesa 61395 Tape$8.95
Remove the display.
Use a Phillips #000 driver to remove the six 3.4mm screws holding on the back panel.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use tweezers to carefully lift the back panel off of the phone.
Use a Phillips #000 screwdriver to remove the 2.4mm screw securing the battery clip over the battery connector.
Using the tweezers carefully disconnect the battery from the motherboard.
Pull off the two pieces of black adhesive tape on the battery.
In this case, use the spudger to also separate any extra adhesive under the battery.
crwdns2935229:016crwdne2935229:0
crwdns2947412:05crwdne2947412:0
Is more glue needed when the display is put back in? The guide doesn’t mention that process.
Terry Cameron - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Yes when you re-install the display you’ll need to add more adhesive as it destroy it during the removal process. They recommend using '''Tesa 61395 Tape (1mm)''' however I got away with using 2mm tape as it was all I had on hand and it worked just fine, however the application was a little difficult. I’d also recommend getting some small conductive tape for the display adhesive pads as well as the couple of conductive pads on the bottom of the battery.
Justin W - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
can you also do the putting it back guide pls
Deepa Patri (CONT) - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Is there any possibility of paying you to do this procedure on my Essential phone? I'm local to you, I think, and would supply the battery.
Let me know how to get in touch.
Thanks!
Vincent - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Just want to say the Battery model you need is HE323 but looking up "Essential Phone Battery" should suffice.
FangerZero - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
