Sometimes the outer case of the device can become cracked or damaged. This guide will show you how to remove the outer case.
Inser the flat end of a spudger into one of the two notches and pry off the case.
Slide the spudger around the perimeter of the radar housing until the case separates.
Repeat these steps to remove the other side.
To reassemble your device, simply place the pieces in their original places, and gently snap them closed.
