Epson VS250 Shell Replacement
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Epson VS250 Shell Replacement, Shell: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the projector on a flat surface.
    • Orient the projector so that the the word "Epson" is facing you.
    • Using the Phillips #1 screwdriver, to loosen the screw on the top right corner of the projector. The screw only needs to be loosened.
  2. Epson VS250 Shell Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the cover to the right and lift the cover up and out to remove.
  3. Epson VS250 Shell Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #1 screwdriver, remove the three 6 mm screws that hold the side portion of the projector in place.
    • Use the same Phillips #1 screwdriver to remove the single 10 mm screw that is holding the side cover of the projector in place.
  4. Epson VS250 Shell Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove the two 10 mm screws that are holding the side cover of the projector in place.
  5. Epson VS250 Shell Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Epson VS250 Shell Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the projector so that it lays upside down.
    • Using a Phillips #1 screwdriver, remove the eight 10 mm screws that secure the side portion of the projector.
  6. Epson VS250 Shell Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the front cover from the projector by pulling it off of the device.
  7. Epson VS250 Shell Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove the two 10 mm screws.
    • After completing this step you will be able to remove the back cover from the projector.
  8. Epson VS250 Shell Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slowly lift up the top shell up and out of the device.
    • Disconnect the ribbon cable from the motherboard and remove the shell from the device.
Justin Ogihara
crwdns2935283:009/18/17crwdne2935283:0
29,396 crwdns2915208:0crwdne2915208:0
crwdns2935297:052crwdne2935297:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 22
