To get to the inside parts of the printer, the housing components must come off.
Turn off the printer.
Disconnect all data connections coming into the printer such as USB, networkd cables, firewire, etc. as well as removing the power cord.
Locate the IEEE cover in the back.
Gently slide the cover to the right to unlatch, then pull to remove it.
errore avevo chiesto informazioni x sostituire la batteria al cellulare HUAWEI Mod. LX1
avevo chiesto informazioni x la sostituzione della batteria cellulare HUAWEI Mod.LX1
Using a Phillips #2 screwdriver, remove the four 10 mm screws shown.
Remove the 6 mm screw that holds the rear housing in place.
Remove the rear housing by pulling it backwards.
Insert a plastic opening tool into the cutouts of the lower housing.
Release the two tabs of the side housing by lifting the tool in an upward motion.
Remove the side housing by pulling it outwards.
Using the same method, remove the other side housing.
Lift the paper support.
Open the printer cover and front cover.
Remove the four 10 mm Phillips #2 screws from the sides of the printer.
Remove the three 6 mm Phillips #2 screws.
Detach the tabs from the pins on each side by pulling it outwards.
Remove the two 10 mm Phillips #2 screws on the front of the printer.
Disconnect the two cables on the side by carefully pulling it outwards.
Remove the upper housing by lifting it upwards.
this is where I get stuck. the top won't come off. it seems to be stuck at the right front corner, where the buttons are. Is the button grouping part of the upper housing or does it come separate from the upper housing unit. The picture appears that you are taking the button attachment as part of the upper housing unit. But it is really stuck there on my 1400.
crwdns2935229:010crwdne2935229:0
Thank you so much, Larry! I am repurposing my 1400 for sublimation printing and need to get the print head a little easier than standard methods! Much appreciated!
