Epson Stylus Photo 1400 Housing Replacement
  1. Epson Stylus Photo 1400 Housing Replacement, Housing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn off the printer.
    • Disconnect all data connections coming into the printer such as USB, networkd cables, firewire, etc. as well as removing the power cord.
  2. Epson Stylus Photo 1400 Housing Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Epson Stylus Photo 1400 Housing Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the IEEE cover in the back.
    • Gently slide the cover to the right to unlatch, then pull to remove it.
  3. Epson Stylus Photo 1400 Housing Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Epson Stylus Photo 1400 Housing Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #2 screwdriver, remove the four 10 mm screws shown.
    • Remove the 6 mm screw that holds the rear housing in place.
  4. Epson Stylus Photo 1400 Housing Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Epson Stylus Photo 1400 Housing Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the rear housing by pulling it backwards.
  5. Epson Stylus Photo 1400 Housing Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Epson Stylus Photo 1400 Housing Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Epson Stylus Photo 1400 Housing Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a plastic opening tool into the cutouts of the lower housing.
    • Release the two tabs of the side housing by lifting the tool in an upward motion.
    • Remove the side housing by pulling it outwards.
  6. Epson Stylus Photo 1400 Housing Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Epson Stylus Photo 1400 Housing Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Both side housings are attached by the same type of mechanism.
    • Using the same method, remove the other side housing.
  7. Epson Stylus Photo 1400 Housing Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Epson Stylus Photo 1400 Housing Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Epson Stylus Photo 1400 Housing Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the paper support.
    • Open the printer cover and front cover.
  8. Epson Stylus Photo 1400 Housing Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Epson Stylus Photo 1400 Housing Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Epson Stylus Photo 1400 Housing Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four 10 mm Phillips #2 screws from the sides of the printer.
    • Remove the three 6 mm Phillips #2 screws.
  9. Epson Stylus Photo 1400 Housing Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Epson Stylus Photo 1400 Housing Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Detach the tabs from the pins on each side by pulling it outwards.
  10. Epson Stylus Photo 1400 Housing Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Epson Stylus Photo 1400 Housing Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 10 mm Phillips #2 screws on the front of the printer.
  11. Epson Stylus Photo 1400 Housing Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Epson Stylus Photo 1400 Housing Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Epson Stylus Photo 1400 Housing Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the two cables on the side by carefully pulling it outwards.
    • You may need to gently rock the two cables up and down while pulling.
  12. Epson Stylus Photo 1400 Housing Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Epson Stylus Photo 1400 Housing Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the upper housing by lifting it upwards.
    • It's easier to lift the housing by gripping it from the bottom.
crwdns2935229:010crwdne2935229:0
Larry Huang
crwdns2935283:010/12/11crwdne2935283:0
1,022 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 17-11, Regan Fall 2011 crwdns2935289:0Cal Poly, Team 17-11, Regan Fall 2011crwdne2935289:0
CPSU-REGAN-F11S17G11
Thank you so much, Larry! I am repurposing my 1400 for sublimation printing and need to get the print head a little easier than standard methods! Much appreciated!
ryan Caputo - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 7,909
