The motherboard is a large component within the Epson Powerlite S4. This unit is located in the lower corner, and helps communicate with other technical components. Before starting this guide, ensure that the projector is off to prevent any hazard. If the motherboard is malfunctioning, chances are the device will not work.
Press the power button located on top of the projector.
Using the Phillips #1 screwdriver, loosen the single captive screw on the right side of the projector.
Slide the panel off and remove it from the device.
Remove seven black 10 mm screws from the bottom of the device using a Phillips #1 screwdriver.
Remove three smaller silver screws using a Phillips #1 screwdriver.
Turn the projector so the power button is on top.
Gently pull up the cover until it pops off.
Disconnect the ribbon cable that attaches the cover to the motherboard.
Remove the cover and place to the side.
Remove the three screws holding down the motherboard using a Phillips #1 screwdriver.
Ensure that the two large cable cords located in the center are disconnected.
Remove the nine cables that are running to the motherboard by pulling them up out of their sockets.
Carefully lift the motherboard from the edges.
Remove from base and set aside.
