Epson PowerLite S4 Exhaust Fan Replacement
  1. Epson PowerLite S4 Exhaust Fan Replacement, Exhaust Fan: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the bottom of the projector facing you, use a Phillips #00 screwdriver to remove the seven screws.
  2. Epson PowerLite S4 Exhaust Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove one screw on the backside of the projector.
    • Slide the panel off.
  3. Epson PowerLite S4 Exhaust Fan Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the top frame from the backside of the projector, with care not to damage any connections.
    • Disconnect the two cables from the motherboard.
  4. Epson PowerLite S4 Exhaust Fan Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove one screw.
    • Lift the fan and its mount up and out of the projector.
  5. Epson PowerLite S4 Exhaust Fan Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the two screws securing the fan to its housing, then gently pull them apart to separate each piece.
To reassemble your device, follow these instructions in reverse order using the new exhaust fan.
Max Askew
crwdns2935283:003/28/22crwdne2935283:0
221 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 1-1, Petersen Spring 2022 crwdns2935289:0UMass Dartmouth, Team 1-1, Petersen Spring 2022crwdne2935289:0
UMASSD-PETERSEN-S22S1G1
crwdns2942667:0crwdne2942667:0 259
