If your Epson PowerLite Home Cinema 1040 (model V11H772020 or H772A) fan constantly runs even right after you turn the projector on and the lamp is still cool, there could be an issue with the temperature sensor. The temperature sensor in the Epson PowerLite Home Cinema 1040 is a green chip about the size of a nickel. It has 2 wires that plug into the motherboard. If there is a malfunction with this sensor, the projector will constantly think it is overheating, and the fans will constantly run and the projector may even shut off.
This guide demonstrates the steps necessary for replacing your temperature sensor.
Before beginning, make sure to turn off the projector and unplug the power cord.
Turn off the projector and unplug the power cord.
Use the Phillips #2 screwdriver to remove the 9 mm screw that secures the lamp cover.
Slide off the lamp cover and remove it from the projector.
Use the Phillips #1 (PH1) screwdriver to remove the three 7 mm screws around the perimeter of the lens cover.
Remove the air filter cover.
Remove the two PH1 7mm screws from under the air filter cover.
Remove the two black, PH1, 6mm screws.
Flip the projector so the bottom is exposed.
Remove seven PH1 7mm screws on the outer rim of the projector.
Continuing on the bottom, remove the two black, PH1, 6mm screws.
Remove the cover on the backside of the projector where the inputs are located.
Pull the top half of the housing upwards and rest it on the side.
Using your fingernail or another thin wedging tool, disconnect the electronic strip from the motherboard.
Remove the top half of the projector housing completely and set it to the side.
Use the Philips #1 to unscrew the 3 silver 7mm screws securing the fan frame in place.
Locate the temperature sensor above the cooling fan.
Pull the green temperature sensor chip out of the plastic housing that keeps it in place.
Unhook the red and black temperature sensor wires that lead to the motherboard.
Remove the temperature sensor from the projector.
What happens when you just remove the part, will it never turn on? I’m trying to find a replacement sensor for my 1080 but I’ve had no luck so far.
