Epson PowerLite Home Cinema 1040 Removing Housing
  1. Epson PowerLite Home Cinema 1040 Removing Housing, Removing Housing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn off the projector and unplug the power cord.
    • Allow the projector lamp to cool down for an hour or more to prevent injury.
  2. Epson PowerLite Home Cinema 1040 Removing Housing: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Epson PowerLite Home Cinema 1040 Removing Housing: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Epson PowerLite Home Cinema 1040 Removing Housing: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the Phillips #2 screwdriver to remove the 9 mm screw that secures the lamp cover.
    • Slide off the lamp cover and remove it from the projector.
    • If the lamp is broken, glass fragments may be found when removing the lamp cover. Be careful when removing the lamp cover and when removing the glass.
  3. Epson PowerLite Home Cinema 1040 Removing Housing: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Epson PowerLite Home Cinema 1040 Removing Housing: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Epson PowerLite Home Cinema 1040 Removing Housing: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the Phillips #1 (PH1) screwdriver to remove the three 7 mm screws around the perimeter of the lens cover.
  4. Epson PowerLite Home Cinema 1040 Removing Housing: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Epson PowerLite Home Cinema 1040 Removing Housing: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Epson PowerLite Home Cinema 1040 Removing Housing: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the air filter cover.
    • Remove the two PH1 7mm screws from under the air filter cover.
  5. Epson PowerLite Home Cinema 1040 Removing Housing: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Epson PowerLite Home Cinema 1040 Removing Housing: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Epson PowerLite Home Cinema 1040 Removing Housing: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two black, PH1, 6mm screws.
  6. Epson PowerLite Home Cinema 1040 Removing Housing: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Epson PowerLite Home Cinema 1040 Removing Housing: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Epson PowerLite Home Cinema 1040 Removing Housing: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the projector so the bottom is exposed.
    • Remove seven PH1 7mm screws on the outer rim of the projector.
    • Some screws are located deeper in the housing and a bit extension or longer screwdriver may be required.
  7. Epson PowerLite Home Cinema 1040 Removing Housing: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Epson PowerLite Home Cinema 1040 Removing Housing: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Continuing on the bottom, remove the two black, PH1, 6mm screws.
  8. Epson PowerLite Home Cinema 1040 Removing Housing: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Epson PowerLite Home Cinema 1040 Removing Housing: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the cover on the backside of the projector where the inputs are located.
  9. Epson PowerLite Home Cinema 1040 Removing Housing: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Epson PowerLite Home Cinema 1040 Removing Housing: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Epson PowerLite Home Cinema 1040 Removing Housing: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the top half of the housing upwards and rest it on the side.
    • Be careful to not pull upwards too hard. The top is still connected by a thin electric strip.
  10. Epson PowerLite Home Cinema 1040 Removing Housing: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Epson PowerLite Home Cinema 1040 Removing Housing: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Epson PowerLite Home Cinema 1040 Removing Housing: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using your fingernail or another thin wedging tool, disconnect the electronic strip from the motherboard.
    • Remove the top half of the projector housing completely and set it to the side.
Connor Didericksen
crwdns2935283:002/09/23crwdne2935283:0
727 crwdns2915208:0crwdne2915208:0
Utah Tech University, Team 1-6, McMurrin Spring 2023 crwdns2935289:0Utah Tech University, Team 1-6, McMurrin Spring 2023crwdne2935289:0
UTAHTECH-MCMURRIN-S23S1G6
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 304
