Epson PowerLite 77c Fan Replacement
  1. Epson PowerLite 77c Fan Replacement, Lamp: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the one 5.0 mm screw from the lamp cover on the back of the device.
  2. Epson PowerLite 77c Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the cover toward you, then lift it to remove it.
  3. Epson PowerLite 77c Fan Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Epson PowerLite 77c Fan Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Loosen the two 5.0 mm captive screws with a Phillips #0 screwdriver.
    • Captive screws cannot be fully removed. Simply loosen the captive screws until the lamp housing releases, but do not attempt to remove them.
    • Pinch the two release triggers to unlatch the lamp housing, and lift upward to remove it.
  4. Epson PowerLite 77c Fan Replacement, Fan: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the seven 5.0 mm screws on the base panel.
    • Pick up the projector with both hands, sandwiching the top and bottom of the projector together, and place it right-side-up, with the ports facing you.
    • Lift the top panel up.
    • Two connectors are holding the top panel to the motherboard; be careful not to damage them as you lift the top panel.
  5. Epson PowerLite 77c Fan Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Epson PowerLite 77c Fan Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the locking bar of the ZIF connector vertically, then delicately remove the ribbon cable.
    • Grip the cable connector as close as possible to the plug, then pull it straight up until it releases from the motherboard.
    • Remove the top panel.
  6. Epson PowerLite 77c Fan Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the two 5.0 mm screws.
  7. Epson PowerLite 77c Fan Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Epson PowerLite 77c Fan Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the one 5.0 mm screw on the right side of the gap with a Phillips #0 screwdriver.
    • Remove the one 5.0 mm screw on the left side of the gap with a Phillips #0 screwdriver.
  8. Epson PowerLite 77c Fan Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • On the right side of the motherboard, grip the plug labeled "PWR-FAN" and pull straight up to detach the fan from the motherboard.
  9. Epson PowerLite 77c Fan Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Epson PowerLite 77c Fan Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grip the fan and lift it up and out.
Xandher Thao
crwdns2935283:002/08/22crwdne2935283:0
161 crwdns2915208:0crwdne2915208:0
Western Carolina University, Team 1-6, Virtue Spring 2022 crwdns2935289:0Western Carolina University, Team 1-6, Virtue Spring 2022crwdne2935289:0
WCU-VIRTUE-S22S1G6
crwdns2942667:0crwdne2942667:0 256
