If your device is on and there is no light coming from the bulb it is safe to say that the bulb itself is no longer functioning properly or has burned out. Replacement lamps can be found on the market, but you can buy bulbs to replace from the bulb cannister and replace them that way. Bulbs do tend to burn out throughout time because of use and time, it is important to make sure to check on these parts and replace them if they no longer functioning.
Remove the screw from the corner panel that houses the bulb chamber using a Phillips #0 screwdriver.
Slide off the panel by pulling it away from the machine.
Remove the two screws from the top of the black casing using a Phillips #0 screwdriver.
Pull the casing out of its chamber.
Remove the four screws from the bottom of the casing using a Phillips #0 screwdriver.
Remove the top and side of the casing from the bulb.
Remove the old light build and replace it with your new one.
