A key part of the Epson Brightlink 450Wi is the speakers. Although audio can be played via external speakers, the ones built in ensure some kind of audio output no matter your setup. That's why it's important to know how fix them in the case they aren't working properly.
In the event of faulty speakers or when in need of replacement, follow this guide.
Remove the 11 mm screws from the bottom of the device using a long-handle Phillips screwdriver.
Remove the 11 mm screws from the air filter section and power source section.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Remove the 11 mm screws around the speaker. Use tweezers to move wires out of the way to locate screws.
Once the screws are removed, the speaker can be removed.
