Epomaker Shadow-X Switch Plate Re-alignment
  1. Epomaker Shadow-X Switch Plate Re-alignment, Switch Plate Replacement: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Epomaker Shadow-X Switch Plate Re-alignment, Switch Plate Replacement: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Epomaker Shadow-X Switch Plate Re-alignment, Switch Plate Replacement: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Power off the keyboard and disconnect any USB cable.
    • Place the keyboard on a clean, static-free workspace.
  2. Epomaker Shadow-X Switch Plate Re-alignment: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a keycap puller/spudger to remove all keycaps on the keyboard.
  3. Epomaker Shadow-X Switch Plate Re-alignment: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws on the back of the keyboard with a hex screwdriver.
    • Carefully pry open the case using a plastic opening tool or spudger, and separate the top and bottom halves.
  4. Epomaker Shadow-X Switch Plate Re-alignment: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the switch plate, which sits between the key switches and the PCB.
    • If the switch plate is misaligned, carefully adjust it so that it sits flush and aligns with all switch positions.
    • Ensure that each switch slot in the plate lines up with the PCB holes below it.
  5. Epomaker Shadow-X Switch Plate Re-alignment: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If the plate has screws or clips, check that each one is correctly fastened to prevent future misalignment.
    • Gently press on different sections of the plate to verify that it’s stable and correctly positioned over the PCB.
  6. Epomaker Shadow-X Switch Plate Re-alignment: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Epomaker Shadow-X Switch Plate Re-alignment: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Epomaker Shadow-X Switch Plate Re-alignment: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Reinsert each switch, ensuring that they align with both the switch plate and the PCB.
    • Snap the top and bottom halves of the case back together. Replace and tighten all screws.
    • Reinstall all keycaps and check that they are aligned and consistent in height.
You have successfully realigned the switch plate on your Epomaker Shadow-X keyboard! This adjustment improves switch stability and typing consistency. Check each key to confirm the alignment, and enjoy smoother, more consistent typing.
Beck Spitler
crwdns2935283:008/28/24crwdne2935283:0
611 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 6-1, Kilpatrick Fall 2024 crwdns2935289:0University of North Texas, Team 6-1, Kilpatrick Fall 2024crwdne2935289:0
UNT-KILPATRICK-F24S6G1
crwdns2942667:0crwdne2942667:0 179
