crwdns2959928:0crwdne2959928:0 ↓Follow these steps to properly replace the strings to your Epiphone ES-335 PRO electric guitar. This may be necessary due to having old or broken strings. Make sure you replace the corresponding strings to the correct tuners, which is labeled on the new strings' package.
Using the tuner, loosen the string by turning the tuner.
Continue to loosen the string until it is easily unwrapped and pulled out of the tuner.
On the bridge of the guitar, push the string through the back until the other end is visible. Then grasp and pull the string all the way out.
