crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Envision EN7410crwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Envision EN7410 Teardown, Removing the stand: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Envision EN7410 Teardown, Removing the stand: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the monitor on its screen side down
    • Remove the four screws holding the stand onto the monitor
  2. Envision EN7410 Teardown, Remove backing: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Envision EN7410 Teardown, Remove backing: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Envision EN7410 Teardown, Remove backing: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To remove the backing, remove the two screws holding the case in place.
    • The monitor is held in place with clips. Lightly bend the backing backwards to separate the frame from the screen
  3. Envision EN7410 Teardown, Remove lower circuit board screws: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Envision EN7410 Teardown, Remove lower circuit board screws: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • We must first remove the circuits connected to the buttons used to calibrate the monitor
    • Remove this section by unscrewing the three screws holding it in place
    • Remember that this section is connected by wires, and should be handled carefully
  4. Envision EN7410 Teardown, Disconnect  cable from top circuit board: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Envision EN7410 Teardown, Disconnect  cable from top circuit board: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Hold right below the cables and pull the cable apart from the top circuit board
  5. Envision EN7410 Teardown, Remove side screws: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There are four screws on each side of the monitor that you must remove to disassemble the rest of the monitor
    • These screws are relatively tiny, so make sure that they are stored securely
  6. Envision EN7410 Teardown, Removing Circuit board casing: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Envision EN7410 Teardown, Removing Circuit board casing: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the backing of the circuit board by unscrewing the four screws holding it in place
    • Make sure Step 3 was completed in full because it is connected to this part
  7. Envision EN7410 Teardown, Remove side panels and tape: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Envision EN7410 Teardown, Remove side panels and tape: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Envision EN7410 Teardown, Remove side panels and tape: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove these panels after the past steps have been completed in full
    • Remove the tape covering any of the screws or wires we will remove in future steps
  8. Envision EN7410 Teardown, Remove screws to upper circuit board: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three screws on the circuit board
    • Use the mini Philip's head
  9. Envision EN7410 Teardown, Remove screws from side circuit board: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two smaller screws on the side circuit board
    • Remember to use the mini Philip's head
  10. Envision EN7410 Teardown, Removing metal frame: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Envision EN7410 Teardown, Removing metal frame: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Envision EN7410 Teardown, Removing metal frame: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pop away the metal frame surrounding the LCD monitor
    • This is similar to removing the other frame in step 2
  11. Envision EN7410 Teardown, Removing the black LCD screen: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Envision EN7410 Teardown, Removing the black LCD screen: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Envision EN7410 Teardown, Removing the black LCD screen: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Raise the green circuit boards up
    • Holding the screen vertically, slide the black screen off
  12. Envision EN7410 Teardown, Removing the LCD Glass Panel: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Envision EN7410 Teardown, Removing the LCD Glass Panel: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Envision EN7410 Teardown, Removing the LCD Glass Panel: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the plastic filter sheets covering the LCD glass panel
    • Place your fingers on the sides of the glass panel and lift it upwards to remove it
  13. Envision EN7410 Teardown, Remove the inner black frame: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Envision EN7410 Teardown, Remove the inner black frame: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the monitor white side up
    • Just like the previous frames, pop the plastic black frame apart from the rest of the monitor
  14. Envision EN7410 Teardown, Removing electronics from monitor: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Envision EN7410 Teardown, Removing electronics from monitor: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • gently lift the two metal bars connected to the circuit board.
    • This will separate the two components apart
    • You have successfully completed a teardown of the Envision EN7410 monitor
Anthony Fontes
crwdns2935283:006/15/16crwdne2935283:0
111 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 1,114
