The first step of disassembling the Engage Wired Optical Mouse is to remove the outer shell and main top component of the mouse without damaging any parts.
Note that the circuit board has capacitors. Though they aren't very dangerous, you may wish to discharge them before handling the circuit board. A tool to accomplish this can be found here.
Flip the mouse over and peel off the stickers on the perimeter of the bottom of the mouse.
Use the Phillips #1 screwdriver to remove four 5 mm screws from the bottom of the mouse.
Use the Phillips #1 screwdriver to remove the two 9 mm screws from the bottom of the mouse.
Grab the top shell of the mouse and lift up to remove.
Touch your capacitor discharge tool to the capacitor leads on the board to release the stored energy. If leads are inaccessible, wait until you've removed the board from the mouse body.
Use a spudger to pry underneath the white plug and pop it out to disconnect the upper board from the lower board.
