Enabot EBO SE Battery Replacement
  1. Enabot EBO SE Battery Replacement, Wheel Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently turn the robot upside down.
    • Place the robot on a stable surface to prevent it from rolling or falling.
  2. Enabot EBO SE Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Enabot EBO SE Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Enabot EBO SE Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a flathead 2.5 mm screwdriver to remove the 5.7 mm screw from the wheels.
    • A tool should have been provided in the box for this purpose.
  3. Enabot EBO SE Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Enabot EBO SE Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the wheel assembly towards you so it comes straight off without resistance.
    • If there is resistance, make sure to apply gentle force when pulling as it can get damaged with too much force.
  4. Enabot EBO SE Battery Replacement, Lower Housing: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Enabot EBO SE Battery Replacement, Lower Housing: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Torx screwdriver to remove the four 9 mm screws from the assembly.
  5. Enabot EBO SE Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Enabot EBO SE Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Enabot EBO SE Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingernail to carefully press down and eject the Micro SD Card from the back of the Enabot.
    • Keep the Micro SD Card in a safe spot for later.
  6. Enabot EBO SE Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Enabot EBO SE Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the iFixit opening tool inside the Micro SD slot.
    • Very carefully apply pressure to the top of the slot and pry open the casing to separate the upper and lower housing.
  7. Enabot EBO SE Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Enabot EBO SE Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Enabot EBO SE Battery Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the iFixit opening tool or your fingernail, place it underneath the gray tab on the lower housing.
    • Lift the tab up and pull out the ribbon cable to disconnect it from the lower housing.
  8. Enabot EBO SE Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Enabot EBO SE Battery Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Enabot EBO SE Battery Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There are two black and red wire connectors attached to the upper and lower housing.
    • Gently use your finger nails to lift up and disconnect both wires to fully separate the upper and lower housings.
  9. Enabot EBO SE Battery Replacement, Battery: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Enabot EBO SE Battery Replacement, Battery: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Enabot EBO SE Battery Replacement, Battery: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the iFixit opening tool or your fingernail to disconnect the cable by placing the edge underneath the gray tab.
    • Flip the tab up and pull the ribbon cable out.
    • Disconnect the red and blue wires from the daughterboard by using your finger nails to pull up on the connector to disconnect.
  10. Enabot EBO SE Battery Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Enabot EBO SE Battery Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Enabot EBO SE Battery Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove both 7.4 mm screws from the side of the battery's casing.
  11. Enabot EBO SE Battery Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Enabot EBO SE Battery Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the battery casing upwards from the lower half of the assembly to remove it.
  12. Enabot EBO SE Battery Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Enabot EBO SE Battery Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully remove the battery from the casing in order to replace.
Kevin H.
crwdns2935283:002/15/24crwdne2935283:0
692 crwdns2915208:0crwdne2915208:0
University of Memphis, Team 4-5, Sneed Spring 2024 crwdns2935289:0University of Memphis, Team 4-5, Sneed Spring 2024crwdne2935289:0
UM-SNEED-S24S4G5
crwdns2947412:05crwdne2947412:0
Una guía fantástica, pero no puedo seguirla porque no encuentro el recambio de la batería ¿Se puede usar una genérica? ¿Alguna referencia que me ayude a encontrar el recambio?
Rubén Belmonte - crwdns2934203:0crwdne2934203:0
tengo la misma duda, entendí perfecto el tutorial, que tipo de batería lleva?
Marina Daniela Regali - crwdns2934203:0crwdne2934203:0
18650 battery with ph2.0/2p connector
Camilo Jiménez - crwdns2934203:0crwdne2934203:0
Do you know what's the original battery capacity in mah?
wcy pierre -
crwdns2936753:07crwdne2936753:0 40
crwdns2936753:030crwdne2936753:0 136
crwdns2942667:0crwdne2942667:0 1,779
