The valve allows water to move through the device in order for the water to be vaporized and ultimately emitted. If the device doesn't emit vapor or leaks, the water valve may not be functioning properly. It may also be possible that it isn't attached tightly enough. We will demonstrate the steps to take out the valve and then replace it.
Gently lift the cover off the humidifier.
Gently pull the water tank off the base.
Locate the valve at the bottom of the tank.
Twist counterclockwise to remove the valve.
Where can I buy a replacement valve and cord?
Thank you
Tammy
