Use a spudger to open your device's case, revealing the inside.
Disconnect the LCD cable from the motherboard by pressing the two sides of the clamp together.
Use the spudger to pry the LCD from the clamps that hold it in the case.
After disconnecting the LCD from the motherboard, remove the screws that hold down the motherboard.
Remove the plastic power and volume buttons.
Remove the two side grips of the device.
Remove the motherboard, the speaker, and the battery, leaving just the back casing of the device.
