Ematic Genesis 2 Charging Port Replacement
  1. Ematic Genesis 2 Charging Port Replacement, Charging Port: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ematic Genesis 2 Charging Port Replacement, Charging Port: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
  2. Ematic Genesis 2 Charging Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ematic Genesis 2 Charging Port Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ematic Genesis 2 Charging Port Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove all four screws surrounding the battery with the Phillips head screwdriver.
    • Carefully remove the battery from the device using the Metal Spudger tool to gently separate the battery by wedging it between the device and the battery.
  3. Ematic Genesis 2 Charging Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ematic Genesis 2 Charging Port Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove both screws on either side of the audio jack using the Philips head screwdriver.
    • Detach audio jack from device.
  4. Ematic Genesis 2 Charging Port Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ematic Genesis 2 Charging Port Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 3 screws surrounding the circuit board using the Philips head screwdriver.
    • Carefully disconnect the circuit board from the device by detaching the copper flexible PCB ribbon cable.
  5. Ematic Genesis 2 Charging Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ematic Genesis 2 Charging Port Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a soldering iron to heat the solder holding the charging port to the circuit board.
    • Remove the charging port from board using tweezers.
  6. Ematic Genesis 2 Charging Port Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Solder replacement port into place.
    • Make sure all connections match original.
Alexandria Ehrnsberger
crwdns2935283:008/26/15crwdne2935283:0
137 crwdns2915208:0crwdne2915208:0
Western Carolina University, Team 1-1, Virtue Fall 2015 crwdns2935289:0Western Carolina University, Team 1-1, Virtue Fall 2015crwdne2935289:0
WCU-VIRTUE-F15S1G1
crwdns2942667:0crwdne2942667:0 614
