Ematic Genesis 2 Battery Replacement
  1. Ematic Genesis 2 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ematic Genesis 2 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
  2. Ematic Genesis 2 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ematic Genesis 2 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ematic Genesis 2 Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove all four screws surrounding the battery with a Phillips Head Screwdriver.
    • Carefully remove the battery from the device using the Metal Spudger tool to gently separate the battery by wedging it between the device and the battery.
  3. Ematic Genesis 2 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Desoldering Pump
    $3.99
    • Carefully remove the solder that connects the battery wires to the device using the solder sucker tool and a soldering iron.
    • When using the soldering iron to heat the existing solder, do not damage the device or surrounding connections.
    • Once all solder is gone, remove the wires from the device to free the battery.
  4. Ematic Genesis 2 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the soldering iron to solder the wires from the new battery to the device.
    • The connections from the wires should go in order from left to right being white, black (negative), and red (positive), respectively.
Brandon Key
crwdns2935283:008/26/15crwdne2935283:0
246 crwdns2915208:0crwdne2915208:0
Western Carolina University, Team 1-1, Virtue Fall 2015 crwdns2935289:0Western Carolina University, Team 1-1, Virtue Fall 2015crwdne2935289:0
WCU-VIRTUE-F15S1G1
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 437
