Ematic FunTab 3 Touch Screen Replacement
crwdns2869540:0crwdne2869540:0: 1425
4
15
58
1.425
crwdns2955950:0crwdne2955950:0: 3
crwdns2960004:02crwdne2960004:0, crwdns2960006:01crwdne2960006:0
crwdns2959984:0crwdne2959984:0: 0
crwdns2959956:0crwdne2959956:0
crwdns2955944:0crwdne2955944:0: 25 - 40 crwdns2931279:0crwdne2931279:0
If your device remains blank or seems to not power on when pressing the power button, a screen replacement may be necessary. If the device's display is damaged, this guide will show you the steps to replacing your defective screen. After following the necessary steps to remove the battery and motherboard, replacing the screen is very quick.
    1. Ematic FunTab 3 Touch Screen Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ematic FunTab 3 Touch Screen Replacement, Back Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ematic FunTab 3 Touch Screen Replacement, Back Panel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Turn off the device before starting
      • To prevent damage, open the device on the side without the buttons.
      • Insert the hooked end of the plastic opening tool in the gap between the screen and the back panel on the edge of the device.
      • Slide the plastic opening tool down the long side of the device.
      • Insert tool again and slide it down the long slide of the case a second time.
    2. Ematic FunTab 3 Touch Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pull the back panel away from the screen.
    1. Ematic FunTab 3 Touch Screen Replacement, Motherboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the black tape to reveal the screen connector.
    2. Ematic FunTab 3 Touch Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ematic FunTab 3 Touch Screen Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Flip up the retaining tab using the plastic opening tool.
      • Pull out the screen wire ribbon to disconnect the screen and motherboard.
    3. Ematic FunTab 3 Touch Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ematic FunTab 3 Touch Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using a PH 00 screwdriver, remove the four 4.5 mm screws that are holding the motherboard in place.
    4. Ematic FunTab 3 Touch Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • It is now safe to remove and replace the old motherboard with your new motherboard.
      • Close the black ribbon retaining tabs once ribbons are inserted during reassembly.
    1. Ematic FunTab 3 Touch Screen Replacement, Touch Screen: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ematic FunTab 3 Touch Screen Replacement, Touch Screen: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Insert the hook side of the opening tool between the case and display.
      • Press down on the tool until the screen is clear of the white retaining tabs.
      • Use the plastic opening tool to gently pry up the screen.
      • This is best done on the corner closest to the wire ribbon.
      • Continue prying around the screen until the screen pops out.
    2. Ematic FunTab 3 Touch Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • After the screen has come lose, remove it from the device.
      • When reassembling, make sure the screen locks in place, this may require extra pressure
Amanda Davis
crwdns2935283:007/11/18crwdne2935283:0
581 crwdns2915208:0crwdne2915208:0
UW Tacoma, Team S1-G5, Cardinal Summer 2018 crwdns2935289:0UW Tacoma, Team S1-G5, Cardinal Summer 2018crwdne2935289:0
UWT-CARDINAL-SU18S1G5
Where can I get a new display for my emoticons funtab 3?
DanTheMan RBLX - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 58
crwdns2959996:0crwdne2959996:0 1,425
