crwdns2959928:0crwdne2959928:0 ↓If your device is not holding a charge, or only functions when plugged into the charger, then this guide will show how to fix this problem by replacing the battery. This process could take anywhere from 15-30 minutes, and requires you to detach and desolder all of the battery's connection to the device.
Insert the hooked end of the plastic opening tool in the gap between the screen and the back panel on the edge of the device.
Slide the plastic opening tool down the long side of the device.
Insert tool again and slide it down the long slide of the case a second time.
Pull the back panel away from the screen.
Remove the black tape to reveal the wire ribbon connector.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Flip up the black retaining tab using the plastic opening tool.
Pull out the large wire ribbon that crosses over the battery.
Insert the plastic opening tool under the battery.
Using the plastic opening tool, pry up the battery.
Remove the wires from the motherboard using a soldering iron tool. Here is a link on How To Solder and Desolder Connections.
After the connections are desoldered, remove the battery.
