If you need to open your device or replace the back panel, this guide will show you how.
Insert the hooked end of the plastic opening tool in the gap between the screen and the back panel on the edge of the device.
Slide the plastic opening tool down the long side of the device.
Insert tool again and slide it down the long slide of the case a second time.
Pull the back panel away from the screen.
Our funtab3 is not work because we want to work but Anything is not work. We see a tiny crack
