Ematic EGQ307 Digitizer Replacement
    1. Ematic EGQ307 Digitizer Replacement, Digitizer: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ematic EGQ307 Digitizer Replacement, Digitizer: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • There are two screws on the side with the micro USB power port. Remove the two 2mm x 0.5mm screws with a Phillips #0 Screwdriver head.
    2. Ematic EGQ307 Digitizer Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ematic EGQ307 Digitizer Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pry off the plastic backing with the spudger and the plastic opening tools. Anything that can provide enough leverage and not conduct electricity will also work for this purpose.
      • Carefully separate the front and back plates because the wire that connects the speaker is connected to both the front and back plates.
    3. Ematic EGQ307 Digitizer Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ematic EGQ307 Digitizer Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ematic EGQ307 Digitizer Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      Plastic Cards
      $2.99
      • Once you pry off the plastic backing, you will expose the battery and the motherboard.
      • Remove the tape holding the battery to the plastic frame. The battery is glued to the back of the LCD.
      • Pry the battery off the LCD using a flat and rigid piece of plastic, such as the plastic card.
    4. Ematic EGQ307 Digitizer Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ematic EGQ307 Digitizer Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ematic EGQ307 Digitizer Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Carefully remove the tape holding the camera in place as the camera is attached to the backing of the tape.
      • Gently lift up the black lever that’s holding the camera ribbon in place using a long piece of stiff plastic.
      • Now, remove the camera from the device.
    5. Ematic EGQ307 Digitizer Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ematic EGQ307 Digitizer Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ematic EGQ307 Digitizer Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the three 2mm x 0.5mm screws with a Phillips #0 Screwdriver head from the motherboard.
      • Carefully remove the motherboard from the LCD backing. Remove tape from the edges of the LCD.
      • Carefully pry off the LCD with a piece of plastic.
      • Carefully remove the motherboard, battery, and the speaker, so wires do not get disconnected.
    6. Ematic EGQ307 Digitizer Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ematic EGQ307 Digitizer Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ematic EGQ307 Digitizer Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Now Protective Screen is removed and is ready to be replaced.
Jonathan Scinto
crwdns2935283:007/21/15crwdne2935283:0
530 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team 1-1, Rowley SU 2015 crwdns2935289:0Eastern Washington University, Team 1-1, Rowley SU 2015crwdne2935289:0
EWU-ROWLEY-SU15S1G1
crwdns2936753:030crwdne2936753:0 96
crwdns2942667:0crwdne2942667:0 1,424
