Ematic EGQ307 Battery Replacement
  1. Ematic EGQ307 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ematic EGQ307 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There are two screws on the side with the micro USB power port. Remove the two 2mm x 0.5mm screws with a Phillips #0 Screwdriver head.
  2. Ematic EGQ307 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ematic EGQ307 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry off the plastic backing with the spudger and the plastic opening tools. Anything that can provide enough leverage and not conduct electricity will also work for this purpose.
    • Carefully separate the front and back plates because the wire that connects the speaker is connected to both the front and back plates.
  3. Ematic EGQ307 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • 3. Once you pry off the plastic backing, you will expose the battery.
  4. Ematic EGQ307 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ematic EGQ307 Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ematic EGQ307 Battery Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Plastic Cards
    $2.99
    • 4. Remove the tape holding the battery to the plastic frame. The battery is glued to the back of the LED. Pry the battery off the LED using a plastic card.
    • Do not bend or warp the battery. Even though the battery may not be working, it is still dangerous.
  5. Ematic EGQ307 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If replacing the battery, unplug the black and red wires gently from the hardware and take off the battery .
    • If not replacing it, do not disconnect the red and black wires.
    • If replacing the battery, you will need a soldering kit to reconnect the wires with the new battery after disconnecting the old battery.
    • How To Solder and Desolder Connections.
To reassemble your device, follow these instructions in reverse order. Note, you need to solder the battery wires onto the motherboard.
Othman
crwdns2935283:007/21/15crwdne2935283:0
267 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team 1-1, Rowley SU 2015 crwdns2935289:0Eastern Washington University, Team 1-1, Rowley SU 2015crwdne2935289:0
EWU-ROWLEY-SU15S1G1
crwdns2942667:0crwdne2942667:0 5,286
