Eluktronics N850HK SSD Replacement
  1. Eluktronics N850HK SSD Replacement, SSD: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Eluktronics N850HK SSD Replacement, SSD: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Eluktronics N850HK SSD Replacement, SSD: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push both switch locks inward to unlock the battery from the bottom panel.
    • The switch on the left must be held in place.
    • Remove the battery from the back of the laptop.
  2. Eluktronics N850HK SSD Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Eluktronics N850HK SSD Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the twelve 4 mm screws from the bottom panel of the laptop.
  3. Eluktronics N850HK SSD Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Eluktronics N850HK SSD Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the four 3 mm screws located under where the battery usually rests.
    • Do not remove the two additional screws near the bottom screw. These are connected to the motherboard and do not need to be removed.
  4. Eluktronics N850HK SSD Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Eluktronics N850HK SSD Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the back case off and identify the SSD in the lower right corner.
    • Although the chances of damage are low, it is important to be aware of static electricity in your surroundings when working a computer motherboard. Ground yourself or use an anti-static wrist strap.
  5. Eluktronics N850HK SSD Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Eluktronics N850HK SSD Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Eluktronics N850HK SSD Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove 3 mm screw securing the SSD.
    • The SSD will naturally lift by a few millimeters.
    • Carefully slide the SSD from the M.2 slot.
  6. Eluktronics N850HK SSD Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Eluktronics N850HK SSD Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Eluktronics N850HK SSD Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the ridges on the right side to align the SSD properly.
    • Slide the new SSD into the M.2 mounting slot.
    • Use the Phillips #00 screwdriver to replace the 3 mm screw that secures the SSD.
  7. Eluktronics N850HK SSD Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Eluktronics N850HK SSD Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Eluktronics N850HK SSD Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Reassemble by following the directions in reverse order.
Alternative models where this guide may still apply:
  • Eluktronics N857HK1
  • Eluktronics N850HP6
Brandon Yuan
crwdns2935283:006/22/24crwdne2935283:0
226 crwdns2915208:0crwdne2915208:0
Austin Community College, Team 6-12, Watkins Summer 2024 crwdns2935289:0Austin Community College, Team 6-12, Watkins Summer 2024crwdne2935289:0
AUSTINCC-WATKINS-SU24S6G12
crwdns2936753:07crwdne2936753:0 54
crwdns2936753:030crwdne2936753:0 247
crwdns2942667:0crwdne2942667:0 3,958
