Element GC-1020 Screen Replacement
    1. Element GC-1020 Screen  Replacement, Back Cover Replacement Guide: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unscrew the four screws (size: 3.175mm) on the left and right side of the Element Electronics GC-1020 device using the PH#0 screwdriver.
    2. Element GC-1020 Screen  Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Carefully pull the back of the device (the silver portion) apart from the rest of the device.
      • If you pull back too forcefully the power button would move out of place.
    1. Element GC-1020 Screen  Replacement, Screen: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unscrew the bottom of left and right sides of the motherboard.
      • Notice these screws are slightly larger than the ones on the outside of the device.
    2. Element GC-1020 Screen  Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Element GC-1020 Screen  Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Carefully bend the plastic frame to remove the motherboard.
      • Be sure that the power button, stays attached to the outer frame, as moving the motherboard it may cause it to loosen.
    3. Element GC-1020 Screen  Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Element GC-1020 Screen  Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Element GC-1020 Screen  Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Detach the screen by disconnecting the thin piece of ribbon cable attached to the PCB (printed circuit board).
      • Use a pair of tweezers to carefully pull the ribbon from the circuit board.
      • Take care not to damage the ribbon, as you will need it intact to reattach your new screen.
    4. Element GC-1020 Screen  Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Element GC-1020 Screen  Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Element GC-1020 Screen  Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Carefully pry apart the screen from the frame of the device.
      • Separate the two by peeling away the thin plastic layer that makes up the screen of the device.
      • If done correctly, your detached screen will look like this.
Lashaun Noel
crwdns2935283:009/25/15crwdne2935283:0
591 crwdns2915208:0crwdne2915208:0
University of Tampa, Team 1-4, Whiteside Fall 2015 crwdns2935289:0University of Tampa, Team 1-4, Whiteside Fall 2015crwdne2935289:0
UT-WHITESIDE-F15S1G4
crwdns2936753:030crwdne2936753:0 51
crwdns2942667:0crwdne2942667:0 691
