Electrical Plug Replacement
  1. Electrical Plug Replacement, Two-Pole Plug: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Electrical Plug Replacement, Two-Pole Plug: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Be sure to unplug the lamp.
    • Locate the damaged portion of wire.
    • Cut the damaged plug from the lamp cord one inch below the damaged area
  2. Electrical Plug Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Electrical Plug Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Separate the wire by gently pulling it apart.
    • The wire with the raised ribbing on the coating is the neutral wire.
    • The hot wire has a smooth coating.
  3. Electrical Plug Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Electrical Plug Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Electrical Plug Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Strip the coating off the wire.
    • Expose 3/4" of the copper wire.
    • Twist the exposed copper wire so that there is no fraying.
    • Twisting the wires ensures the strongest connection and maximum safety.
  4. Electrical Plug Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Electrical Plug Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Loosen the screw and open the replacement plug.
    • The silver screw is the neutral connection, and the brass screw is the hot connection.
    • The different connections must be determined in order to properly wire the replacement plug.
  5. Electrical Plug Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Electrical Plug Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Electrical Plug Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Wrap the neutral wire around the neutral screw. Tighten the screw to secure the wire.
    • Remember the neutral wire is the wire with raised ribbing on the coating.
    • Wrap the hot wire around the brass screw. Tighten the screw to secure the wire.
  6. Electrical Plug Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Electrical Plug Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Thread the cord so the plug will completely close.
    • Tighten the exterior screw to close the plug.
    Where can I purchase a new plug
    Marlene4950 - crwdns2934203:0crwdne2934203:0
    You can purchase it at almost every hardware store.
    Toon Konings - crwdns2934203:0crwdne2934203:0
If the lamp the does not work after replacing the plug, the issue may be located in the bulb housing or in the connections.
crwdns2935229:018crwdne2935229:0
Tim Spellings
crwdns2935283:007/17/15crwdne2935283:0
571 crwdns2915208:0crwdne2915208:0
Texas Tech, Team 3-2, Rauch SU 2015 crwdns2935289:0Texas Tech, Team 3-2, Rauch SU 2015crwdne2935289:0
TTU-RAUCH-SU15S3G2
crwdns2947412:07crwdne2947412:0
A version for 3 prong (North American) would be great
James Harrison - crwdns2934203:0crwdne2934203:0
https://www.noveltylights.com/coaxial-6-...
How would you repair a coaxial cord wire right where it enters the screw on part?
olgaocon - crwdns2934203:0crwdne2934203:0
what do you do if the replacement plug has no screws to open it?
Kristin Ladd - crwdns2934203:0crwdne2934203:0
Buy a plug that can be opened with a screw
Toon Konings -
How can you tell hot wire from neutral wire?
Dr. Karakas - crwdns2934203:0crwdne2934203:0
the neutral wire usually has raised ribbing on its sleeve, and the hot wire has a smooth rubber sleeve. (See Step 2 of the guide)
Ben Eccles -
crwdns2936753:07crwdne2936753:0 65
crwdns2936753:030crwdne2936753:0 318
crwdns2942667:0crwdne2942667:0 49,975
