crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Electric Whiskcrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Electric Whisk Teardown, Separate attachment from motor body: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Electric Whisk Teardown, Separate attachment from motor body: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Electric Whisk Teardown, Separate attachment from motor body: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Press the eject buttons to release the attachment from the motor body. With this done, pull the lowest casing away.
  2. Electric Whisk Teardown, Separate whisk tool from casing: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Simply by pulling the two components on opposite directions.
  3. Electric Whisk Teardown, Separate speed control dial from motor body: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Electric Whisk Teardown, Separate speed control dial from motor body: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Electric Whisk Teardown, Separate speed control dial from motor body: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the speed dial all the way down to number ‘1’. Now, using a flathead screwdriver, lever off the dial using the edge aligned with the number ‘15’ as the pivot point.
  4. Electric Whisk Teardown, Remove top case: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Electric Whisk Teardown, Remove top case: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Electric Whisk Teardown, Remove top case: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove two screws fixing the top case to the body with the screwdriver and pull the casing away from the motor body.
  5. Electric Whisk Teardown, Remove the chord clamp: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Electric Whisk Teardown, Remove the chord clamp: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Electric Whisk Teardown, Remove the chord clamp: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove two screws fixing to the plastic component holding the circuit board and chord.
  6. Electric Whisk Teardown, Detach trigger mechanism and spur gear: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Electric Whisk Teardown, Detach trigger mechanism and spur gear: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The trigger mechanism consists of a nylon component and a spring. No tools are required to remove this part and you can pull it out with your fingers. The same goes for the spur gear which simply slides out.
  7. Electric Whisk Teardown, Seperate the casing (Part A): crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • In production, the top casing is glued to the bottom casing. For this reason, the casing needs to be sawn apart. Clamp the top casing in place so that it does not slip. (See the attached photographs for an example of a clamping setup.)
  8. Electric Whisk Teardown, Seperate the casing (Part B): crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Electric Whisk Teardown, Seperate the casing (Part B): crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Proceed to saw all the way around the top casing, approximately 5mm from the button. If done correctly, the smaller component should slide off, taking the motor and circuit board with it. You may need to employ a twisting and pulling action.
  9. Electric Whisk Teardown, Remove rubber seal: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Electric Whisk Teardown, Remove rubber seal: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The seal is located on the motor. Remove it by sliding it up over the circuit board.
  10. Electric Whisk Teardown, Remove nylon whisk driver: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Electric Whisk Teardown, Remove nylon whisk driver: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Electric Whisk Teardown, Remove nylon whisk driver: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using pliers, simply grip and pull the piece away.
  11. Electric Whisk Teardown, Remove motor from cut casing: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Electric Whisk Teardown, Remove motor from cut casing: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Electric Whisk Teardown, Remove motor from cut casing: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Set up the motor and remaining casing in a vice as shown in the picture. Take the dowel and place it in the opening of the remaining casing, and rest it on the metal whisk driver. GENTLY hammer downwards on the dowel until the motor falls through.
  12. Electric Whisk Teardown, Detaching circuit board from motor: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Electric Whisk Teardown, Detaching circuit board from motor: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Electric Whisk Teardown, Detaching circuit board from motor: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The circuit board is slotted into two grooves on the motor. Use one side of the circuit board and your thumbs as a pivot point to lever off the opposite side of the board. (See the photo for reference). The other side should now come away easily.
Boris Huoth
crwdns2935283:010/02/18crwdne2935283:0
205 crwdns2915208:0crwdne2915208:0
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 68
crwdns2942667:0crwdne2942667:0 1,950
