Electric Lint Remover Blade Replacement
  1. Electric Lint Remover Blade Replacement, Blade: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Electric Lint Remover Blade Replacement, Blade: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the lint container by sliding to the right until it clicks off.
    • Remove any lint from the lint container for a clean process.
  2. Electric Lint Remover Blade Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Electric Lint Remover Blade Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Electric Lint Remover Blade Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Rotate the perforated cap counterclockwise until it can be removed.
  3. Electric Lint Remover Blade Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Electric Lint Remover Blade Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your flathead screwdriver to get in between the device and the blades.
    • Push the plastic blade holder outward from the device until it pops off.
  4. Electric Lint Remover Blade Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Electric Lint Remover Blade Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the wire out of the defective blade's hole, using the flathead screwdriver.
  5. Electric Lint Remover Blade Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Electric Lint Remover Blade Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Electric Lint Remover Blade Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the replacement blade into the empty slot.
    • Caution: pinching the replacement blade from surface may result in injury.
  6. Electric Lint Remover Blade Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Electric Lint Remover Blade Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the cap onto its backside and firmly hold down the side with the loose blade.
    • Pull back the wire using your fingers, and insert wire back into the blade hole.
  7. Electric Lint Remover Blade Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Electric Lint Remover Blade Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Electric Lint Remover Blade Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the plastic blade holder back on the shaft of the device, by aligning the hexagonal hole on the cap with the shaft.
    • Press down gently on the plastic blade cap.
    • Caution: Make sure to press on the cap and not on the blades, otherwise action may cause injury.
  8. Electric Lint Remover Blade Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Electric Lint Remover Blade Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place perforated cap on top of the blade cap and turn clockwise until tight.
  9. Electric Lint Remover Blade Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Electric Lint Remover Blade Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the lint container to the left and press until it clicks into place.
We hope this guide helped you. Happy Fixing!
Chris Koenig
crwdns2935283:010/03/23crwdne2935283:0
184 crwdns2915208:0crwdne2915208:0
CSU Los Angeles, Team 9-4, Ribeiro Fall 2023 crwdns2935289:0CSU Los Angeles, Team 9-4, Ribeiro Fall 2023crwdne2935289:0
CSULA-RIBEIRO-F23S9G4
crwdns2942667:0crwdne2942667:0 693
