Follow this guide to remove the Auto-Feed mechanism from your Electric Eel 75’ Drain Cleaner Z5K12IC75AF for replacement or further disassembly.
Twist the guide spring counter-clockwise to unscrew it from the auto-feeder.
Remove the guide spring.
Unscrew the tension knob to loosen the tension spring in the top feeder assembly.
Set the feeder adjustment knob in the neutral position, in between the "FWD" and "REV" positions.
Push the top control finger up as far as possible.
Use a 1/2" open-ended wrench to remove the two bolts from the bottom of the feeder body mounting arm.
Remove the auto-feeder from the cable.
crwdns2947412:05crwdne2947412:0
Removal of what part number? Replace with part number xxx.. Needed to do the job of replacing a part IS the part and it's part number.
Bearing part number
DE-10SET
Mark W -
So how do you take the rest apart to change out the bearings.
Where can I get replacement parts I.e. shear pin/roller for the exact tool shown in your video?
I need a auto feeder for electric eel
