Eightarc Fusion USB Cable Replacement
  1. Eightarc Fusion USB Cable Replacement, USB Cable: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Eightarc Fusion USB Cable Replacement, USB Cable: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Because of the protruding joystick on the top of the controller, make sure to work on a soft surface or prop the controller up to avoid stress on the joystick.
    • Place the controller face down (buttons and joystick down).
    • Use a Phillips Head #1 screwdriver to remove the eight 9.65 mm screws located on the felt and metal backplate.
    • Do not confuse the four screws in the rubber feet with the eight screws in the felt. The screws in the feet do not need to be removed.
  2. Eightarc Fusion USB Cable Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the door for the cord storage compartment on the right side of the device.
    • Reach under the panel and push upwards on the back panel. Lift it up and remove it from the device.
  3. Eightarc Fusion USB Cable Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With flap unlatched, gently bend the flap and pull slightly to get the pegs out of the socket
    • Be sure to be gentle and not snap the plastic flap in half.
  4. Eightarc Fusion USB Cable Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide USB cable up from the plastic barrier casing.
  5. Eightarc Fusion USB Cable Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Eightarc Fusion USB Cable Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Eightarc Fusion USB Cable Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The USB cord is connected to the logic board by a plastic plug with five wires.
    • Gently pull up and wiggle the white plastic end attached to the wires out of the mother board.
    • The white casing on top pulls off from its counterpart on the logic board. Do not take off the bottom part of the white fixture from the logic board.
    • Remove USB cable from device.
Dana
crwdns2935283:002/01/15crwdne2935283:0
141 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 17-35, Amido Winter 2015 crwdns2935289:0Cal Poly, Team 17-35, Amido Winter 2015crwdne2935289:0
CPSU-AMIDO-W15S17G35
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 913
