The motherboard compartment is the central identity of the duck and if water gets inside of it, Edwin will no longer work. With this guide, we are going to help you through the steps of replacing the rubber gasket seal, which prevents water from entering the motherboard compartment of Edwin.
Unscrew the four 9mm screws with aT8 bit
Take the back plate off
Using the J1 bit, unscrew all six 9 mm screws around the border.
Use the plastic opening tool to open the inside of the duck.
Insert your new rubber gasket in and use the plastic opening tool to push the rubber gasket into it's slot
