Edco KL14 Arbor Replacement
  1. Edco KL14  Arbor Replacement, Disengage the Spark Plug: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Edco KL14  Arbor Replacement, Disengage the Spark Plug: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin, ensure that the machine is powered down and cool to the touch.
    • Disconnect the spark plug to prevent the engine from accidentally starting up during service:
    • Grab the plastic spark plug cap at the end of the spark plug wire.
    • Firmly pull to disconnect the spark plug cap from the spark plug.
  2. Edco KL14  Arbor Replacement, Place Wheel Chocks: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Edco KL14  Arbor Replacement, Place Wheel Chocks: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Edco KL14  Arbor Replacement, Place Wheel Chocks: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To prevent the concrete saw from rolling during service, place wheel chocks in front of and behind a rear wheel.
  3. Edco KL14  Arbor Replacement, Remove the Arbor Guard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Edco KL14  Arbor Replacement, Remove the Arbor Guard: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a 3/8-inch wrench to remove the two bolts securing the arbor guard.
    • Remove the arbor guard.
  4. Edco KL14  Arbor Replacement, Remove the Belt Guard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Edco KL14  Arbor Replacement, Remove the Belt Guard: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Edco KL14  Arbor Replacement, Remove the Belt Guard: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a 3/8-inch wrench to remove the two bolts securing the belt guard.
    • Remove the belt guard.
  5. Edco KL14  Arbor Replacement, Arbor: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Edco KL14  Arbor Replacement, Arbor: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lower the guide bar all the way down until it rests on the work surface.
  6. Edco KL14  Arbor Replacement, Remove the Blade: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 9/16-inch wrench to remove the bolt securing the blade cover.
  7. Edco KL14  Arbor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 3/4-inch wrench to loosen the blade cover pivot bolt, but do not remove it.
  8. Edco KL14  Arbor Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Edco KL14  Arbor Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Raise the blade cover all the way up to expose the cutting blade.
    • Work slowly and take extra precautions when working around the exposed cutting blade.
  9. Edco KL14  Arbor Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Edco KL14  Arbor Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Edco KL14  Arbor Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the included wrenches to remove the jam nut securing the cutting blade to the arbor.
    • Use one wrench behind the blade to secure the arbor in place as you use the other wrench to remove the jam nut.
    • The jam nut is accompanied by a lock washer. Be sure to retain it for reinstallation.
  10. Edco KL14  Arbor Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Edco KL14  Arbor Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Edco KL14  Arbor Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the blade cap.
    • Reassembly Tip: Make sure the pin on the blade cap lines up with the holes on the blade and arbor.
  11. Edco KL14  Arbor Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Edco KL14  Arbor Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Edco KL14  Arbor Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the blade from the arbor.
    • Use extreme care while removing the blade to avoid injury.
  12. Edco KL14  Arbor Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 9/16-inch wrench to remove the four bolts securing the arbor assembly to the concrete saw.
  13. Edco KL14  Arbor Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Edco KL14  Arbor Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Support the arbor assembly from the bottom and tilt the left side down to remove it from the belts.
  14. Edco KL14  Arbor Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Edco KL14  Arbor Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the arbor assembly.
    • Reassembly Tip: Reinstall a mounting bolt on the blade side to hold the arbor assembly in place. Then use a clamp to help line up the remaining mounting bolt holes, as the tension of the belts will make it difficult to do this by hand.
Craig Lloyd
crwdns2935283:002/10/16crwdne2935283:0
40,495 crwdns2915208:0crwdne2915208:0
crwdns2935297:082crwdne2935297:0
I'd really like to see this type of guide done on a machine that has been USED by say rental customers! I do appreciate the guides but they are somewhat unrealistic because everything is new. Also, I didn't see a part number for a whole and assembled arbor. That would be nice to have.
MICHEL - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,563
