Ecovacs Deebot 900 Wheel Replacement
  1. Ecovacs Deebot 900 Wheel Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all the brushes from the Deebot.
  2. Ecovacs Deebot 900 Wheel Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #0 screwdriver, remove the two 12.25 mm screws holding the battery cover in place.​
  3. Ecovacs Deebot 900 Wheel Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery cover.
    Anyone know where I can buy the battery for the Deebot 900. Evovacs is saying they won’t/dont sell them.
    Mike - crwdns2934203:0crwdne2934203:0
  4. Ecovacs Deebot 900 Wheel Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the two white straps on the sides of the battery, gently remove the battery. ​
    • Be careful not to rip out the battery cable.
  5. Ecovacs Deebot 900 Wheel Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully disconnect the battery cable by pulling near the connector at the bottom of the battery compartment.
    I have two issues with these instructions.
    Title is Ecovacs Deebot 900 Battery Replacement. The battery was never replaced the device was reassembled.
    For battery replacement you need a battery it would be nice to have the replacement battery part number as well.
    Rick Sargent - crwdns2934203:0crwdne2934203:0
    I’d like some more info on part numbers, too. I have a Deebot 901 with a battery that, already after 2 years, has deteriorated significantly. Deebot 901 is also called “DE5G.10” in Europe, and it’s existing Battery back has model number ZJ1517-HFR, on which I can find almost no info, let a lone a compatible part somewhere in The Netherlands.
    eymert -
  6. Ecovacs Deebot 900 Wheel Replacement, Front Bumper: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ecovacs Deebot 900 Wheel Replacement, Front Bumper: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #00 screwdriver, remove the eight screws on the bottom edge of the bumper. ​
  7. Ecovacs Deebot 900 Wheel Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the black strip on the bottom of the bumper.
  8. Ecovacs Deebot 900 Wheel Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ecovacs Deebot 900 Wheel Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully lift up the bumper untill it pops out of place.​
  9. Ecovacs Deebot 900 Wheel Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ecovacs Deebot 900 Wheel Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the two cables connecting the bumper to the body of the Deebot.
    • Remove the front bumper from the device.
  10. Ecovacs Deebot 900 Wheel Replacement, Bottom Case: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ecovacs Deebot 900 Wheel Replacement, Bottom Case: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #00 screwdriver, take out the six screws around the perimeter of the bottom case.
    This was actually to toughest part. I have a Deebot T9+ and it is slightly different (not much) and it is always a bit scary when you have to remove "plastic fixeners"
    RobinB - crwdns2934203:0crwdne2934203:0
  11. Ecovacs Deebot 900 Wheel Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ecovacs Deebot 900 Wheel Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a Jimmy into the seam and work all the way around the robot.
    • Disconnect the two cables and remove the bottom case from the device.
    Thank you for your work on this guide!
    Dominick Borrego - crwdns2934203:0crwdne2934203:0
    Im not able to remove the bottom case. I have a Deebot 711
    rocksmum - crwdns2934203:0crwdne2934203:0
    This step is difficult, but takes some time and patience, keep pulling. I managed to open it by pulling from the front part which was previously covered by the bumper
    Michele Pandini - crwdns2934203:0crwdne2934203:0
  12. Ecovacs Deebot 900 Wheel Replacement, Motherboard: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #00 screwdriver, remove the two black screws holding the motherboard in place.​
  13. Ecovacs Deebot 900 Wheel Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the ribbon cables connected to the top of motherboard.
    • Keep track of where the cables connect to the motherboard.
    It could be give you put letters on the cable connects A to Z on the picture so when putting them back you could check on the picture if you forgot any.
    supertoaster2@gmail.com - crwdns2934203:0crwdne2934203:0
  14. Ecovacs Deebot 900 Wheel Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the last three ribbon cables on the underside of the motherboard.​
  15. Ecovacs Deebot 900 Wheel Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the motherboard out of the Deebot and remove it from the device.
    Salve sto cercando una vostra scheda,mi può aiutare?
    scheda ecovacs zj2025_mb_v0.2_20210301
    Grazie
    xina xin - crwdns2934203:0crwdne2934203:0
  16. Ecovacs Deebot 900 Wheel Replacement, Wheel: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a screwdriver or tweezers, Gently lift the spring upward, ensuring not to apply excessive force that could damage surrounding components. Once the spring is loosened, grip it securely and pull it off from one side, allowing the tension to release naturally. Take care to note the spring’s orientation and placement for reassembly later.
  17. Ecovacs Deebot 900 Wheel Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ecovacs Deebot 900 Wheel Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #00 screwdriver, remove the four screws securing the wheel assembly in place. Begin by loosening each screw slightly to evenly distribute pressure, then fully unscrew them one at a time. Be sure to set the screws aside in a safe location for reassembly later. Gently lift the wheel assembly out of its housing.
  18. Ecovacs Deebot 900 Wheel Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pry off the wheel cover using your fingers or a plastic tool, applying light pressure to release it. Set the cover aside for reassembly.
  19. Ecovacs Deebot 900 Wheel Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ecovacs Deebot 900 Wheel Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ecovacs Deebot 900 Wheel Replacement: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the Phillips #00 screwdriver, remove the three screws holding the side brush motor in place and lift the brush motor up.
  20. Ecovacs Deebot 900 Wheel Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ecovacs Deebot 900 Wheel Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the wheel assembly carefully, ensuring the attached sensor (black cable) comes out with it. Handle the sensor gently to avoid damage
    Come faccio ad aprire la ruota per cambiare lo pneumatico ?
    Scorpion198 Jo - crwdns2934203:0crwdne2934203:0
crwdns2935229:08crwdne2935229:0
Christina Corliss
crwdns2935283:001/16/20crwdne2935283:0
831 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team S6-G1, Rauch Spring 2020 crwdns2935289:0Embry-Riddle Aeronautical University, Team S6-G1, Rauch Spring 2020crwdne2935289:0
ERAU-RAUCH-S20S6G1
crwdns2935297:017crwdne2935297:0
I have an OZMO 930 that the left driver wheel is stuck. I tried to follow the above instruction, but I can’t go beyond step 10, I can’t take out the cover. Any help will be greatly appreciated,
OldManInChicago - crwdns2934203:0crwdne2934203:0
do you have place to buy ecovac_deebot_900_54_gear ?? I thinking on printing it but after my printed gear to papper shreder I have no hopes it will last.
Plewu Gracz - crwdns2934203:0crwdne2934203:0
Thanks for the guide on the Deebot 900 wheel replacement. Though it has partially helps to resolve the problems, but unable to find a wheel replacement. Hope you can help too.
wong CS - crwdns2934203:0crwdne2934203:0
The rubber tires on my Deebot have worn through. Does anybody have a source for rubber tire replacement? The company wants to sell me two entire wheel assemblies. I find that unreasonable.
akobelan - crwdns2934203:0crwdne2934203:0
To every one that got broken motor gears. You can buy them on ali or ebay. Fix is easy and done even as unprofessional as me. You can also print them if you have god material. I've found 3d printing model for this if someone need it- mail/ pm me.
crwdns2936753:07crwdne2936753:0 25
crwdns2936753:030crwdne2936753:0 144
crwdns2942667:0crwdne2942667:0 48,636
