The Ecovacs Deebot 900 is an autonomous vacuuming robot. If the wheels are jammed, the Deebot will not be able to clean around your house. Use this guide to replace the wheel of the Ecovacs Deebot 900.
Remove all the brushes from the Deebot.
Using a Phillips #0 screwdriver, remove the two 12.25 mm screws holding the battery cover in place.
Remove the battery cover.
Anyone know where I can buy the battery for the Deebot 900. Evovacs is saying they won’t/dont sell them.
Using the two white straps on the sides of the battery, gently remove the battery.
Carefully disconnect the battery cable by pulling near the connector at the bottom of the battery compartment.
I have two issues with these instructions.
Title is Ecovacs Deebot 900 Battery Replacement. The battery was never replaced the device was reassembled.
For battery replacement you need a battery it would be nice to have the replacement battery part number as well.
I’d like some more info on part numbers, too. I have a Deebot 901 with a battery that, already after 2 years, has deteriorated significantly. Deebot 901 is also called “DE5G.10” in Europe, and it’s existing Battery back has model number ZJ1517-HFR, on which I can find almost no info, let a lone a compatible part somewhere in The Netherlands.
eymert -
Using a Phillips #00 screwdriver, remove the eight screws on the bottom edge of the bumper.
Remove the black strip on the bottom of the bumper.
Carefully lift up the bumper untill it pops out of place.
Disconnect the two cables connecting the bumper to the body of the Deebot.
Remove the front bumper from the device.
Using a Phillips #00 screwdriver, take out the six screws around the perimeter of the bottom case.
This was actually to toughest part. I have a Deebot T9+ and it is slightly different (not much) and it is always a bit scary when you have to remove "plastic fixeners"
Insert a Jimmy into the seam and work all the way around the robot.
Disconnect the two cables and remove the bottom case from the device.
Thank you for your work on this guide!
Im not able to remove the bottom case. I have a Deebot 711
Using a Phillips #00 screwdriver, remove the two black screws holding the motherboard in place.
Carefully remove the ribbon cables connected to the top of motherboard.
It could be give you put letters on the cable connects A to Z on the picture so when putting them back you could check on the picture if you forgot any.
Remove the last three ribbon cables on the underside of the motherboard.
Lift the motherboard out of the Deebot and remove it from the device.
Salve sto cercando una vostra scheda,mi può aiutare?
scheda ecovacs zj2025_mb_v0.2_20210301
Grazie
Using a screwdriver or tweezers, remove the spring by lifting the spring and pulling it off one side.
Using a Phillips #00 screwdriver, remove the four screws holding the wheel assembly in place.
Using the Phillips #00 screwdriver, remove the three screws holding the side brush motor in place and lift the brush motor up.
Lift up and remove the wheel assembly and the attached sensor (black cable).
crwdns2944067:06crwdne2944067:0
Thanks, it helps a lot
I have an OZMO 930 that the left driver wheel is stuck. I tried to follow the above instruction, but I can’t go beyond step 10, I can’t take out the cover. Any help will be greatly appreciated,
do you have place to buy ecovac_deebot_900_54_gear ?? I thinking on printing it but after my printed gear to papper shreder I have no hopes it will last.
Thanks for the guide on the Deebot 900 wheel replacement. Though it has partially helps to resolve the problems, but unable to find a wheel replacement. Hope you can help too.
The rubber tires on my Deebot have worn through. Does anybody have a source for rubber tire replacement? The company wants to sell me two entire wheel assemblies. I find that unreasonable.
To every one that got broken motor gears. You can buy them on ali or ebay. Fix is easy and done even as unprofessional as me. You can also print them if you have god material. I've found 3d printing model for this if someone need it- mail/ pm me.
