Ecovacs Deebot 900 Vacuum Motor Replacement
  1. Ecovacs Deebot 900 Vacuum Motor Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all the brushes from the Deebot.
  2. Ecovacs Deebot 900 Vacuum Motor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #0 screwdriver, remove the two 12.25 mm screws holding the battery cover in place.​
  3. Ecovacs Deebot 900 Vacuum Motor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery cover.
    Anyone know where I can buy the battery for the Deebot 900. Evovacs is saying they won’t/dont sell them.
    Mike - crwdns2934203:0crwdne2934203:0
  4. Ecovacs Deebot 900 Vacuum Motor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the two white straps on the sides of the battery, gently remove the battery. ​
    • Be careful not to rip out the battery cable.
  5. Ecovacs Deebot 900 Vacuum Motor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully disconnect the battery cable by pulling near the connector at the bottom of the battery compartment.
    I have two issues with these instructions.
    Title is Ecovacs Deebot 900 Battery Replacement. The battery was never replaced the device was reassembled.
    For battery replacement you need a battery it would be nice to have the replacement battery part number as well.
    Rick Sargent - crwdns2934203:0crwdne2934203:0
    I’d like some more info on part numbers, too. I have a Deebot 901 with a battery that, already after 2 years, has deteriorated significantly. Deebot 901 is also called “DE5G.10” in Europe, and it’s existing Battery back has model number ZJ1517-HFR, on which I can find almost no info, let a lone a compatible part somewhere in The Netherlands.
    eymert -
  6. Ecovacs Deebot 900 Vacuum Motor Replacement, Front Bumper: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ecovacs Deebot 900 Vacuum Motor Replacement, Front Bumper: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #00 screwdriver, remove the eight screws on the bottom edge of the bumper. ​
  7. Ecovacs Deebot 900 Vacuum Motor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the black strip on the bottom of the bumper.
  8. Ecovacs Deebot 900 Vacuum Motor Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ecovacs Deebot 900 Vacuum Motor Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully lift up the bumper untill it pops out of place.​
  9. Ecovacs Deebot 900 Vacuum Motor Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ecovacs Deebot 900 Vacuum Motor Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the two cables connecting the bumper to the body of the Deebot.
    • Remove the front bumper from the device.
  10. Ecovacs Deebot 900 Vacuum Motor Replacement, Bottom Case: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ecovacs Deebot 900 Vacuum Motor Replacement, Bottom Case: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #00 screwdriver, take out the six screws around the perimeter of the bottom case.
    This was actually to toughest part. I have a Deebot T9+ and it is slightly different (not much) and it is always a bit scary when you have to remove "plastic fixeners"
    RobinB - crwdns2934203:0crwdne2934203:0
  11. Ecovacs Deebot 900 Vacuum Motor Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ecovacs Deebot 900 Vacuum Motor Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a Jimmy into the seam and work all the way around the robot.
    • Disconnect the two cables and remove the bottom case from the device.
    Thank you for your work on this guide!
    Dominick Borrego - crwdns2934203:0crwdne2934203:0
    Im not able to remove the bottom case. I have a Deebot 711
    rocksmum - crwdns2934203:0crwdne2934203:0
    This step is difficult, but takes some time and patience, keep pulling. I managed to open it by pulling from the front part which was previously covered by the bumper
    Michele Pandini - crwdns2934203:0crwdne2934203:0
  12. Ecovacs Deebot 900 Vacuum Motor Replacement, Vacuum Motor: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the Phillips #00 screwdriver, remove the three screws around the laser unit.
  13. Ecovacs Deebot 900 Vacuum Motor Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ecovacs Deebot 900 Vacuum Motor Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully lift the laser unit off of the motor assembly​.
  14. Ecovacs Deebot 900 Vacuum Motor Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single screw holding the motor assembly in place using the Phillips #00 screwdriver.
  15. Ecovacs Deebot 900 Vacuum Motor Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ecovacs Deebot 900 Vacuum Motor Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the ribbon cable holding the assembly in place.
    • Be careful not to damage the cable.
  16. Ecovacs Deebot 900 Vacuum Motor Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift and remove the motor assembly out of the Deebot.​
    Thats a great tutorial, but where can you buy parts ?
    Joseph Mathews - crwdns2934203:0crwdne2934203:0
crwdns2935229:05crwdne2935229:0
Gillian Blumer
crwdns2935283:001/16/20crwdne2935283:0
614 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team S6-G1, Rauch Spring 2020 crwdns2935289:0Embry-Riddle Aeronautical University, Team S6-G1, Rauch Spring 2020crwdne2935289:0
ERAU-RAUCH-S20S6G1
crwdns2935297:017crwdne2935297:0
Where can you find a replacement vacuum motor for the zoom 930?
Aaron Commons - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 117
crwdns2942667:0crwdne2942667:0 12,466
