The Ecovacs Deebot 900 is an autonomous vacuuming robot. If the vacuum motor is not working, the Deebot will not pick up debris and will be unable to clean. Use this guide to replace the vacuum motor of your Ecovacs Deebot 900.
Remove all the brushes from the Deebot.
Using a Phillips #0 screwdriver, remove the two 12.25 mm screws holding the battery cover in place.
Remove the battery cover.
Anyone know where I can buy the battery for the Deebot 900. Evovacs is saying they won’t/dont sell them.
Using the two white straps on the sides of the battery, gently remove the battery.
Carefully disconnect the battery cable by pulling near the connector at the bottom of the battery compartment.
I have two issues with these instructions.
Title is Ecovacs Deebot 900 Battery Replacement. The battery was never replaced the device was reassembled.
For battery replacement you need a battery it would be nice to have the replacement battery part number as well.
I’d like some more info on part numbers, too. I have a Deebot 901 with a battery that, already after 2 years, has deteriorated significantly. Deebot 901 is also called “DE5G.10” in Europe, and it’s existing Battery back has model number ZJ1517-HFR, on which I can find almost no info, let a lone a compatible part somewhere in The Netherlands.
eymert -
Using a Phillips #00 screwdriver, remove the eight screws on the bottom edge of the bumper.
Remove the black strip on the bottom of the bumper.
Carefully lift up the bumper untill it pops out of place.
Disconnect the two cables connecting the bumper to the body of the Deebot.
Remove the front bumper from the device.
Using a Phillips #00 screwdriver, take out the six screws around the perimeter of the bottom case.
This was actually to toughest part. I have a Deebot T9+ and it is slightly different (not much) and it is always a bit scary when you have to remove "plastic fixeners"
Insert a Jimmy into the seam and work all the way around the robot.
Disconnect the two cables and remove the bottom case from the device.
Thank you for your work on this guide!
Im not able to remove the bottom case. I have a Deebot 711
This step is difficult, but takes some time and patience, keep pulling. I managed to open it by pulling from the front part which was previously covered by the bumper
Using the Phillips #00 screwdriver, remove the three screws around the laser unit.
Carefully lift the laser unit off of the motor assembly.
Remove the single screw holding the motor assembly in place using the Phillips #00 screwdriver.
Disconnect the ribbon cable holding the assembly in place.
Lift and remove the motor assembly out of the Deebot.
Thats a great tutorial, but where can you buy parts ?
crwdns2935229:05crwdne2935229:0
Where can you find a replacement vacuum motor for the zoom 930?
