Ecovacs Deebot 900 Motherboard Replacement
  1. Ecovacs Deebot 900 Motherboard Replacement, Front Bumper: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ecovacs Deebot 900 Motherboard Replacement, Front Bumper: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #00 screwdriver, remove the eight screws on the bottom edge of the bumper. ​
  2. Ecovacs Deebot 900 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the black strip on the bottom of the bumper.
  3. Ecovacs Deebot 900 Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ecovacs Deebot 900 Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully lift up the bumper untill it pops out of place.​
  4. Ecovacs Deebot 900 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ecovacs Deebot 900 Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the two cables connecting the bumper to the body of the Deebot.
    • Remove the front bumper from the device.
  5. Ecovacs Deebot 900 Motherboard Replacement, Bottom Case: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ecovacs Deebot 900 Motherboard Replacement, Bottom Case: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #00 screwdriver, take out the six screws around the perimeter of the bottom case.
    This was actually to toughest part. I have a Deebot T9+ and it is slightly different (not much) and it is always a bit scary when you have to remove "plastic fixeners"
    RobinB - crwdns2934203:0crwdne2934203:0
  6. Ecovacs Deebot 900 Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ecovacs Deebot 900 Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a Jimmy into the seam and work all the way around the robot.
    • Disconnect the two cables and remove the bottom case from the device.
    Thank you for your work on this guide!
    Dominick Borrego - crwdns2934203:0crwdne2934203:0
    Im not able to remove the bottom case. I have a Deebot 711
    rocksmum - crwdns2934203:0crwdne2934203:0
    This step is difficult, but takes some time and patience, keep pulling. I managed to open it by pulling from the front part which was previously covered by the bumper
    Michele Pandini - crwdns2934203:0crwdne2934203:0
  7. Ecovacs Deebot 900 Motherboard Replacement, Motherboard: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #00 screwdriver, remove the two black screws holding the motherboard in place.​
  8. Ecovacs Deebot 900 Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the ribbon cables connected to the top of motherboard.
    • Keep track of where the cables connect to the motherboard.
    It could be give you put letters on the cable connects A to Z on the picture so when putting them back you could check on the picture if you forgot any.
    supertoaster2@gmail.com - crwdns2934203:0crwdne2934203:0
  9. Ecovacs Deebot 900 Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the last three ribbon cables on the underside of the motherboard.​
  10. Ecovacs Deebot 900 Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the motherboard out of the Deebot and remove it from the device.
    Salve sto cercando una vostra scheda,mi può aiutare?
    scheda ecovacs zj2025_mb_v0.2_20210301
    Grazie
    xina xin - crwdns2934203:0crwdne2934203:0
Gillian Blumer
crwdns2935283:001/16/20crwdne2935283:0
614 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team S6-G1, Rauch Spring 2020 crwdns2935289:0Embry-Riddle Aeronautical University, Team S6-G1, Rauch Spring 2020crwdne2935289:0
ERAU-RAUCH-S20S6G1
crwdns2935297:017crwdne2935297:0
Any suggestions on purchase options?
Curtis Tyler - crwdns2934203:0crwdne2934203:0
vakum ozmo 900,hidup terus mati,lampu led juga mati,switch masih posisi on
markus arif - crwdns2934203:0crwdne2934203:0
If anyone is keen to see how to replace a motherboard on the Ecovacs Deebot Ozmo 950 (same for T5), here's a video guide on how I did it: https://youtu.be/jlsOlYYFl8k. If the link doesn't work, search YouTube for "Ecovacs Deebot 950 Stopped Working! How to replace MOTHERBOARD and make it work again!!". The motherboard replacement cost me $90 AUD from AliExpress. Basically, my Deebot 950 was no longer charging despite me installing a new battery replacement, and when I'd turn on the robot, it would back out of the charging dock and then simply turn off (deactivate), and there was nothing I could do. The motherboard is the problem. I replaced it myself and now it works like brand new again. Hopefully my video guide helps others. I was literally on the verge of throwing this cleaner into the rubbish thinking it no longer works.... but gave it one last attempt to fix and glad I did! :)
Jel Builder - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 88
crwdns2942667:0crwdne2942667:0 9,000
