In order to repair any of the internal components of the Ecovacs Deebot 900, the bottom cover must be removed. This will be a required step for repairing anything inside of the robot and must be completed first, so use this guide to open the Ecovacs 900 Deebot.
Remove all the brushes from the Deebot.
Using a Phillips #0 screwdriver, remove the two 12.25 mm screws holding the battery cover in place.
Using the two white straps on the sides of the battery, gently remove the battery.
Carefully disconnect the battery cable by pulling near the connector at the bottom of the battery compartment.
Using a Phillips #00 screwdriver, remove the eight screws on the bottom edge of the bumper.
Remove the black strip on the bottom of the bumper.
Carefully lift up the bumper untill it pops out of place.
Disconnect the two cables connecting the bumper to the body of the Deebot.
Remove the front bumper from the device.
Using a Phillips #00 screwdriver, take out the six screws around the perimeter of the bottom case.
Insert a Jimmy into the seam and work all the way around the robot.
Disconnect the two cables and remove the bottom case from the device.
